- Feb 26, 2013
- 1,657
- 12,405
- Giottiline T60
- Since March 2013
I did attach a short video so I don’t know why you can’t see it.attaching a video might help, or even a short audio clip
I can't see/hear it either?I did attach a short video so I don’t know why you can’t see it.
I can't see a video either. Sorry. But there is no link.I did attach a short video so I don’t know why you can’t see it.
You can't attach a video directly.I did attach a short video so I don’t know why you can’t see it.
you can upload short clips directly using the "Insert video" button (next to the quote button)You can't attach a video directly.
You need to save it to somewhere like YouTube, and then post a link to the video.
Sorry, I stand corrected!you can upload short clips directly using the "Insert video" button (next to the quote button)
That’s a great help as we wondered why we couldn’t see a pump in the tank . We’ll have a look tomorrow and see if we can find it .presumably a Shurflo pressure pump .. not a submersible.
yes they can be noisy if not fitted correctly
1. They should not be screwed down hard onto the floor compressing the rubber grommets .. if it is it will make a hell of a noise .. when fitted correctly the pump should have some movement.. if not, slacken off the fixing screws..
2. The pipework has to be secured so that it cannot rattle .. and check it's not laying against a wall panel which will amplify the noise
3. Lastly.. if it still sounds noisy you can build an acoustic hood or box and place it over it ..use plywood and line with noise absorbing material .. leave a few holes for ventilation
If you have rigid pipework Shurflo also supply a noice silencing kit, basically short pieces of flexible pipe with connectors ..
It’s actually really loud but the video doesn’t record it well. We can’t flush the toilet at night as it’s so loud you’d never sleep through it . Glynn will be a man on a mission tomorrow to locate it and check what you’ve suggestedvideo up now ... sounds about normal to me .. but do check what I said in my last post ,,
Hopefully we’ll locate the pump today and then try what Scotjimland said and your suggestions too. Definitely need to do something as the noise is crazysome times it is not the pump directly, but the pipework connected to it drumming on a hollow hard surface. The resonance works the same as a speaker amplifying the sound. Often simply touching the pipe and the sound vanishes. This is why a pump sounds loud some times but not others depending how the locker is packed
Use a spray bottle to flush at night.It’s actually really loud but the video doesn’t record it well. We can’t flush the toilet at night as it’s so loud you’d never sleep through it . Glynn will be a man on a mission tomorrow to locate it and check what you’ve suggested
What a blooming’ good idea! I have a spray bottle of water already in the bathroom that I use to spray my curly hair in the mornings to save brushing my hair and looking like I’ve been electrocutedUse a spray bottle to flush at night.
We use one when wilding makes the cassette last another day.What a blooming’ good idea! I have a spray bottle of water already in the bathroom that I use to spray my curly hair in the mornings to save brushing my hair and looking like I’ve been electrocuted
take out the mounting screws and put one or two layers of camping/yoga roll mat under then refit longer screws. However that fiamma pump is probably knackered/fubar/snafu and will need replacing soon with that noiseWe’ve located the pump and all the noise does seem to be coming from the pump rather than any pipework. Glynn has loosened the screws but it made no difference to the noise level. Any other ideas on what might reduce the noise? .
The camper was only 1 year old when we bought it in November and all parts are under warranty for 12 months so perhaps we should get them to replace it? We have a Giottiline dealer not far from here so we could take it in there first and get them to look first and then we’ll know if it’s worth contacting the dealership to get it sortedtake out the mounting screws and put one or two layers of camping/yoga roll mat under then refit longer screws. However that fiamma pump is probably knackered/fubar/snafu and will need replacing soon with that noise
