I'd replace it with another gas boiler.…..with a more efficient model? At present we have a Vaillant ecoTEC plus 831 combi boiler that was installed in July 2011, and seems to be working ok (kiss of death!!), but, with the proposed phasing-out of new gas boilers from 2025, is it worth replacing ours now before:-
1. we can only replace it with an electric boiler or heat-pump
2. the price of gas boilers starts to increase as they become more scarce
3. parts for our current boiler are no longer available
4. another reason I haven’t thought of yet!
I know there are several knowledgeable boiler engineers on Fun, so I would be grateful for any comments/advice!
Thanks in advance,
Andy.
Go for a slightly more capacity but the best efficient version you can afford.
Unless you are going to live in your house for another 30 years, I personally don't see the benefit of replacing with heat pumps or anything else at the moment. The cost is currently too high.
Like all technology, it will start to come down in price with time.
I don't normally tune into Jeremy Vine Radio2, but I did not so long ago and they had some guy who fits heat pumps on his show as a guest.
A plumber called in and ran rings around what he was saying.
Basically, for a new build, yes, I agree, it makes sense because everything else about that build is based on modern methods.(insulation etc)
For old / existing properties for a retro fit, there's all sorts to replace. Radiators, valves, some pipe work etc. and the cost was about £10k compared to a new gas boiler fitted for around £2k.
He even hammered him when the guest mentioned the government grant. Apparently, they have halved the grant to what it originally was.
Wouldn't you think that they would be increasing it at this early stage rather than reducing it?
Take a look at www.boxt.co.uk to give you an idea of what's available for what cost and then you can compare with whatever quote your regular plumber/supplier offers.
