- Dec 2, 2019
- 5,200
- 11,812
- Rapido 7065+
- Broken most bits now
The rubber seal on the filter cartridge - it's sort of o-ringyO ring? copper washer surely?
Ah yes, thought you meant the sump plug washer. Seen that done a few times over the years by an apprentice, junior mechanic and muppets at the like of sh!tfit. Car or van using oil and brought in with a "fault" when checked it was the sump plug. Worst was cross threaded plugThe rubber seal on the filter cartridge - it's sort of o-ringy
That would have been one fitter at one depot,,does not mean they are all useless,,,BUSBY.They managed to flood their workshop floor with oil when they managed to miss the O-ring off the filter on a change they did for me on a Jag years ago... Luckily realised whilst it was on the lift and stopped the engine quickly and no damage done
No sure about MoHo but Halfords seem to cheap oil changes.
I would have thought £40 for oil - Filter £10 - 1/2 hour in time £30 -----£80 ----- £100 tops
They do employ proper mechanics at their service stations so yeah. It's only a Fiat van.Would you trust Halfords with your vehicle![]()
Well I trust them with our cycles and find them excellent,,BUSBY.Would you trust Halfords with your vehicle![]()
Can't think of any visit to a garage that hasn't been bad for the car at the time. MOT excepted (when it passed).That would have been one fitter at one depot,,does not mean they are all useless,,,BUSBY.
Same here, used them twice now, first for cambelt and water pump. Secondly minor service -oil and filter change with general check over plus MOT(outsourced). Certainly will use again,I use Hollis Autotech Ltd at Frognall, Deeping St James. 01778348831
Very good service at sensible prices. He will test your brake fluid and only change if it is required. He will also replace your pollen filter if fitted. Normally takes all the wheels off to ensure noting seized and it is better to check brake pads.
Can't find last price but it was very reasonable.
Also known as Peterborough Motorhomes...
steveh57 any chance you can remember how much the minor service and mot was?
Including the VAT and the MOT £152
If you live in the Aldridge, Walsall, North East Birmingham area I use North Birmingham Motors in Aldridge who can accommodate my 3.2 metre high Moho. They have a website if you Google the name. It is there right now having some brakes attended to and the MOT. Not expensive and small, family run outfit which I have used for the past 11 years. They will even deliver back to you.Depends to some extent upon your mileage since the last service.
I don't ask what's 'available' but I tell them what I want done. E.g. I don't want to pay garage rates for someone to top up my washer bottle, brake fluid, check tyre pressures, wiper blades, lights, oil the door hinges etc.
You need to check if it's due a replacement cambelt (usually accompanied by water pump and belt tensioner).
Otherwise I request a change of oil and engine and fuel filters.
I would never use a main dealer with extortionate labour rates.
If you indicate where you are maybe someone can recommend an independent.
Thank you, I am just waiting for a call back to confirm price including fuel filter and diary availability.
All booked, £150 for the interim service, £75 for the filter if I need it (will check previous services) £50 for the MOT
Turns out I know the owners and they live about 100 yards from me in the next street!
Thank you for all the replies/suggestions.
