There are two ways diodes are used on panels. Virtually all of them have blocking diodes which prevent current flowing backwards through them at night. This shouldn't happen with a good regulator but it could happen if the panel was directly connected to a battery. The other type are bypass diodes which ideally should be fitted to each cell but may only be fitted to a group of cells. These allow current to continue flowing if one cell is damaged - or shaded. These diodes significantly reduce the effect of shading. However, because of the additional cost they are not normally fitted to standard panels so you need to buy one which specifically says it has bypass diodes. Expect to pay more.Picking up on a thread from last year. If shading is such a problem with series wired panels what happens with a partially shaded single panel? I thought they had bipass diodes fitted to offset this problem so why does that not work with a pair of series panels?
It seems to me that a partially shaded pair of panels in series will give a higher voltage than a similar shaded pair in parallel. This would mean better performance in the more northern latitudes.
Just to clarify this:There are two ways diodes are used on panels. Virtually all of them have blocking diodes which prevent current flowing backwards through them at night. This shouldn't happen with a good regulator but it could happen if the panel was directly connected to a battery. The other type are bypass diodes which ideally should be fitted to each cell but may only be fitted to a group of cells. These allow current to continue flowing if one cell is damaged - or shaded. These diodes significantly reduce the effect of shading. However, because of the additional cost they are not normally fitted to standard panels so you need to buy one which specifically says it has bypass diodes. Expect to pay more.![]()
