Semi-air suspension valve settings?
2.5 bar both bags, and the system should never loose pressure. I get a slight variation with temperature outside, but nothing major.
I have just finished fitting mine today. My tow bar bottoms out on the road when getting off the drive. Fitting semi air and inflating to 3 bar has raised the rear by 80mm which I hope will be sufficient. I shall give it a try next week.
I was running mine at 3bar, but I have dropped it to 2.5 as the roads are getting worse. I used to hate the idea of going into Belgium, but even their roads are better than ours now. 😂😂
I have two independent lines and 2 gauges with valves. No compressor but use a small handheld rechargeable pump. It looks a bit like an electric drill. I alter them for a bit of levelling. I can do it with a small hand bike pump but when I get above 4 bar it gets difficult.
