Ah, now that's very fetching.Nah he wears 'onesies'! He's got different one for slobbing out, summer, winter etc and one specially for bed time!
Cargo shorts. & no.Blimey, do you need braces as well as a belt to hold your trousers up?![]()
YesWow you must live in a dodgy area![]()
'At home keys not for immedeate use are kept in a keysafe hidden behind a wall in a locked room'Yes
England
At least its not Grangetown "grungetown"
Nor a nice place like cathays.
My keys are hidden well away from the front of the house so that any thief is going to have to spend time in the house which is rarely totally unoccupied and event then the house alarm is on.I think a bigger issue is key safety when your home, a MH was recently taken locally, the perp broke in the house took the keys with wheel clamp, crook lock, door and ignition keys undid the safety devices and simply drove off.
He also took the wheel clamp and crook lock.
And I suspect the insurers won’t pay up.
how come you have 7 keys in the set, suggests to me that each locker has a different key. I have one key for the ignition I(remote which also activates the alarm, plus one for the external lockers (all the same)Nah he wears 'onesies'! He's got different one for slobbing out, summer, winter etc and one specially for bed time!
van remote, petrol flap,milenco exterior door locks,obd lock, clutch claw, steering stop lock,internal lockhow come you have 7 keys in the set, suggests to me that each locker has a different key. I have one key for the ignition I(remote which also activates the alarm, plus one for the external lockers (all the same)
I thought you were asking me then! Good job Gus replied!how come you have 7 keys in the set, suggests to me that each locker has a different key. I have one key for the ignition I(remote which also activates the alarm, plus one for the external lockers (all the same)
On this issue, I have just renewed our insurance with Aib. As a specific question [ one of many] I asked if having a set of keys on the motorhome, even if locked into a secure deadlock safe would qualify for their claims rejections reasons and was told it would .
I have had two spare chipped keys cut, and one unchipped [ dead] key cut. So we can leave the original keys locked up safely at home.
I asked the locksmith if there were any circumstances under which I would require an original key with me, and there were none he knew of, and spare keys could be cut from the ones he had cut for us. The dead key is for when I'm out in the water, but Mrs BBF fancies going off for a wander.
So it seems we must carry all the keys with us at all times, or risk one secreted about the van being found and used for absconding with the vehicle, and nullifying any claim we might try to make. It's a pain but, one we'll have to learn to live with.
On a brighter note, we have just got our log book back, and are now officially 4090kg total weight.![]()
Forgot the key for the wheel clamp and the extra security on the hab door so 4 in allhow come you have 7 keys in the set, suggests to me that each locker has a different key. I have one key for the ignition I(remote which also activates the alarm, plus one for the external lockers (all the same)
Hi, log back was back in my grubby mitts in 4 weeks, so not to bad a turn around.Out of interest how long did it take to get your log book back as I need to do this.
All these locks yet the windows are a bit of flimsy plastic![]()
They may not 'smash' Jim but they aren't difficult to force open by pulling/levering them and breaking the catches as we found out in Pisa when ours was done along with a PVC next door with the recessed windows.Thing is, that flimsy bit of plastic isn't so flimsy at all and is harder to pop or break than any cab quarter light. I've not tried but the new fully recessed windows we are seeing, look like an even tougher nut.
Your car has a flimsy quarterlight, but I'm sure you still lock it.
Expensive if all you do is snap a key.Have one set with us the other is kept at home in a safe, if we were to loose them, then it’s a hire car or plane to go get the other set may sound expensive but… focuses the mind on keeping keys safe.
In my experience entry by flimsy plastic windows happens many times less than popping locks or breaking glass. So saying windows are plastic, why bother with other security is folly. Which is the point I was making. IMO Plastic windows are not the weakest point of entry into your van.They may not 'smash' Jim but they aren't difficult to force open by pulling/levering them and breaking the catches as we found out in Pisa when ours was done along with a PVC next door with the recessed windows
If the key is snapped in a lock it would have to be drilled out and a new key set I guess so you it would be expensive.Expensive if all you do is snap a key.![]()
I've no idea which happens less only from what I've experienced myself and I'm not aware if there are any stats to show how MHs on their own are broken into as opposed to all types of vehicles, however I wouldn't use this as a reason NOT to have an alarm/tracker fitted - anything that can deter a would-be thief is beneficial as even though we didn't lose any stuff when ours was broken into it was a pain having to sort out the window to make it secure again. The thing is with extra security measures is that you need to make it obvious you have them which is why we bought some stickers to put on ours about it being alarmed as well as having the usual flashing led, if there's one nearby which isn't ours won't seem such an easy target.In my experience entry by flimsy plastic windows happens many times less than popping locks or breaking glass. So saying windows are plastic, why bother with other security is folly. Which is the point I was making. IMO Plastic windows are not the weakest point of entry into your van.
