Schaudt and b2b (4 Viewers)
Jan 31, 2022
295
144
70s camper,Weinsberg
Finally getting to need a b2b, before I take everything to pieces what is the white piece of kit behind ebl252.
Was hoping to add a 2nd leisure battery but on previous post seems it will be an expensive option as need to uprated charging capabilities.
56,206
165,028
Your 3rd photo is a Schaudt B2B, I wouldn't recommend them for Lithium as they charge at a cost 14. 2v and don't shut off or go to a float voltage on the Lithium setting.
241
255
Fiat Based Hymer
I am not so sure that is major problem as we never have the engine running long enough, at one time.
The Hymer fitted Schaudt 121545 works very well on our Exsis-i - charging at 45 amps.
Certainly with our Sterling Power batteries; well within the documented tolerences.
360
1,268
Cumbria, UK
Hobby Optima T65 de
Too long
Where are these all located in your Exsis as I have just bought an Exsis 504 and haven’t yet searched for anything other than the EBL?
266
401
Globecar Summit 540
Edit:I think Lenny HB meant constant 14.4V in his post above.
I have our Schaudt 121525 on the gel setting, which drops down to 13.8V (iirc).But my lithium is mainly charged with solar and I have a manual switch in the d+ to the b2b which is switched off most of the time.
243
391
South Yorkshire, UK
Carthago E line 50 D
When offgrid PS fitted my Victron/ lithium upgrade they left the Schaudt in, so get 75amps (25 +50) when driving. In your opinion will this be detrimental to the longevity of the batteries then?
241
255
Fiat Based Hymer
The B2B in our new Hymer Exsis-i 580 is located under an access hatch in the floor (under the table).
Very unlikely, but depends on how much LiFePO4 they fitted.
56,206
165,028
I replaced my Schaudt B2B with a Victron XS, spending all that money on Lithium I didn't see the point of leaving B2B that doesn't have the ideal charging profile for Lithium.
241
255
Fiat Based Hymer
A valid option. But, I already had the Sterling Power lithium from the last van and they been on such a profile for years.
347
617
Warwick, UK
Hymer Exsis-t
The white box in the second and third pictures looks like it could be a protective cover for the wiring.
