SatNav for Motorhomes
Just to be different Snooper Ventura, we have had several of the truck versions over the past 20 years all have been reliable . The Ventura is the Camper/Motorhome version. Would be good to be able to use it a bit more !
+1 excellent gps with massive database of poi if needed, only short coming for me was speaker volume a bit low, easily solved with a remote speaker,
Updating Zenec units is not very easy the first time.
Basically the procedure is:
  • On the Zenec website identify your model (they have dozens, so you have to find exactly the right one)
  • You can then download the instructions (one or two pages, make sure you get correct language!)
  • You will also need to sign up to get an account
  • You will need a card that converts microSD cards into something you an read on your PC (Curry's/PC World)
  • Then, with a pair of tweezers, you remove the MicroSD card, from the unit (Top right on mine, behind a little cover labeled 'map' )
  • Fit the MicroSD card to your PC and then update.
Thanks very much for your help.im 74 and not wholly conversant with computer,added to this when l got my MH ,due to health issues with me,l couldn't get a comprehensive handover from marquis.now I've got your information,l will get updated and fingers crossed I'll be very satisfied.again many thanks, Bri
If you've got a Benivan it should have a Xzent sat nav not a Zenec unit! Mine does. Still uses the same Tom Tom sat nav software. DAB radio is not particularly good but otherwise a good unit.
Reactions: bri
Snooper Ventura S 8000 motorhome version been all over europe can't ever remember having any problems.
Reactions: bri
