Sargent Ec400 wiring (3 Viewers)
Hobbzy
5
Bessacarr E560
Hi all, I'm fitting a b2b charger in my MH by bypassing the split charger within the sargent unit, I know I have to fit an isolation relay to stop both chargers trying to charge at the same time. My question is, should the isolation relay be connected to the vehicle battery or the leisure battery side of the system? Or would either work just a well?
P.s there are 2 live cables each for both the vehicle and leisure batteries in P1 and P2 of the sargent unit does it matter which one is used to connect the relay?
CAB96
1,318
2,552
Stockport, UK
T6 Leisuredrive
Hello and welcome to the forum.
I can't help I'm afraid, but I'm sure someone knowledgeable will be along soon.
May 3, 2021
126
242
South Devon, UK
Autocruise Alto 2013
Since 2021
I fitted a relay to disconnect the engine battery when the engine is running.
You need to disconnect both cables (they use two thinnner cables rather than one thicker cable), so would need a ‘double pole’ relay (effectively two relays in one) or else you’ll have to use two relays as I did.
I guess technically with a suitable crimp and suitably rated relay, you could also use a single relay for both cables by joining both together on the same terminal. I didn’t consider that at the time!
Sep 29, 2019
323
590
Forte
10years
Think I might have a solution here. Need to check my Sargent version in the morning.
H
Hobbzy
5
Bessacarr E560
That's great, thanks JimmE. Instead of using 2 relays couldn't piggyback spade connectors be used to link the 2 thinner cables to the same terminal on the relay? Also do you have any idea of the cable size/amp rating of the thinner cables?
H
Hobbzy
5
Bessacarr E560
What size single cable did you use to connect to the relay?
H
Hobbzy
5
Bessacarr E560
You're more than welcome.
I used a three way spade connector from 12V planet to join my two incoming wires into a single connection for the relay.
12V planet spade
Sep 29, 2019
323
590
Forte
10years
Apologies re the delay. I think I used 16mm2 cable. This is way too much I know but I always way over spec cabling. Excuse the mess in the picture - in one of my other threads I am replacing some of the floor due to an incorrectly sealed gas locker that let in water from day 1.
Sep 29, 2019
323
590
Forte
10years
Woops. Was not 16mm2. Think it was 12mm2 but to be honest on that short a run anything from 6mm2 will do - it's a tiny run
