PeteT1201
Yes or no? Seems straight forward to fit do they make a big difference?
Q? Does that still mean you can dispose in a septic system ?Roof SOG supplemented by Lidl bio pods. Liquidizes the solids a treat.
And me. Little smell on emptying, it pours more easily, and the inside of the cassette remains spotless. I've been using cheap bio washing capsules for 4 SOG, one Thetford "SOG", one caravan, and four motorhomes.me too
If you can put clothes washing water into it then Yes.Q? Does that still mean you can dispose in a septic system ?
When we were last away a week or so back, and after reading another thread on here, had a wee look when removing our cassette for emptying and lo and behold there's a Thetford filter cartridge underneath it!I've had SOG's with door mounted filters, through the floor filters, and a roof vent.
The roof vent is definitely works the best & it doesn't have a filter so no running costs. I recently converted my through the floor one to a roof vent, the only downside is with the wind in the wrong direction & a rooflight open you can get your own back.
The trough the floor ones work reasonably well although the say the filters need changing once a year they really need changing every 3 months. The filters are £25 but easy to refill yourself with active charcoal for about 3 quid.
The door vent ones keep the smell out of the van but can get pongy outside the van again they say change the filter once a year but it really needs changing every month or two. Anything but the genuine filters don't work very well. I really don't think it's worth fitting this type.
The Thetford version has a more powerful fan but they vent out directly under the loo and if the filters aren't changed every few weeks it gets smelly outside but you can refill the filters.
A roof vent SOG is definitely the best option.
Not syphon?The cassette is designed so that if over full (bowl doesn't empty) you can drain excess into a bucket from the emptying spout without removing the cassette. Just in case you weren't aware of it.
That's not right, you shouldn't get a smell inside. You need to check the fan is working. It's possible it has become loose on the shaft and isn't being spun by the motor. You could try disconnecting the pipe from the fan outlet and see if it is moving any air. A lit match should show if it is doing anything but to save your eyebrows use an empty cassette.We have sog roof vented but I still pop a bit of washing powder in as it stops and build up in the cassette, I would fit a stronger sog fan if they did one, as we still get a smell coming up from the toilet when the flap is open.
I have checked all pipes and roof vent all clear.
Active charcoal pellets, they are sold for fish tanks. No experance of the Thetford but I think you either force it apart then fix back with self taper or cut a hole about 20mm then fit a blanking Gromett or cut down wine bottle cork.When we were last away a week or so back, and after reading another thread on here, had a wee look when removing our cassette for emptying and lo and behold there's a Thetford filter cartridge underneath it!
So guess we've got a sog. Since we've had the van from about a year old (now 8 1/2 years old) I would guess it's the original filter!
Anyway. my biggest mistake was to tell management who the following day advised I need to replace the filter as the toilet was ponging! So, checks out the pricing and eh whit!!!
Since the van's in storage any idea how easy is it to replace the contents in the filter and what am I looking to replace it with \ from where, kind sir?![]()
Only if you're brave - I think that's the word I was looking forNot syphon?![]()
The toilet shouldn't be smelly inside the MH. If it is check the fan is working. You should hear a quiet whirring sound when you pull the flap out. If you don't it's broken somewhere. Our van is 8 years old and I've never changed the filter and there is no detectable smell outside - but I do add a dollop of bio liquid after each emptying.When we were last away a week or so back, and after reading another thread on here, had a wee look when removing our cassette for emptying and lo and behold there's a Thetford filter cartridge underneath it!
Yes plenty of whirring and even been on the roof and it blows out ok but still smells in the looThe toilet shouldn't be smelly inside the MH. If it is check the fan is working. You should hear a quiet whirring sound when you pull the flap out. If you don't it's broken somewhere. Our van is 8 years old and I've never changed the filter and there is no detectable smell outside - but I do add a dollop of bio liquid after each emptying.
Does your vent look like this one https://www.soguk.co.uk/sog-toilet-kit-type-f-through-roof-thetford-c250-c260-series/#0050DYes plenty of whirring and even been on the roof and it blows out ok but still smells in the loo![]()
Something's not right as there really should be no smell. You could check the fan is actually drawing air from the cassette. Find a smoker and ask them to blow smoke onto the cassette with the flap open.Yes plenty of whirring and even been on the roof and it blows out ok but still smells in the loo![]()
Yes just like that one when we get home I will investigate further as suggested with some smoke etcDoes your vent look like this one https://www.soguk.co.uk/sog-toilet-kit-type-f-through-roof-thetford-c250-c260-series/#0050D
Another possibility has there been a drain fitted at the lowest point of the vent hose to allow water / condensation to escape or in my case remove a blanking cap.
Think management was just having a moan 'cause I hadn't changed the filter!The toilet shouldn't be smelly inside the MH. If it is check the fan is working. You should hear a quiet whirring sound when you pull the flap out. If you don't it's broken somewhere. Our van is 8 years old and I've never changed the filter and there is no detectable smell outside - but I do add a dollop of bio liquid after each emptying.
