Sounds like yours is the old DI engine which is bullet proof, you can't kill it even if you try.Which transits? Mine has a belt. I have no idea how I would even start to think about bump starting it though so I'm fine..
Its getting more and more like just being in Spain is an offence.
From memory you don't need timing keys just three drill bits to match the hole sizes in the pulleys very easy, quick and cheap to do, worth googling.Yep so I hear.. bunch of bananas on top.. I was worried about the belt as I have no history for it then did some research and discovered that although it is technically an interference engine the most likely damage after a snap at high revs will be bent ouch rods which don't even need head off to replace.. The belt can wait till I've got spare dosh for the timing keys.. looking forward to that weekends work
Be interesting to see some proof of this.......
Why doesnt the chain jump with a fully charged battery.....if the oil pressure is lost then it will be lost regardless of battery state
It will be no different to a jumper lead start.
The reason is on a transit the starter motor turns the engine over in a slow controlled manner (sort of soft start) not a sharp shock as can be in a bump start.
Yep ,just bends push rods. On my works Transit I could change the belt in 45 minutes ! I only ever used bolts of the relevant diameter to lock flywheel, pump , etc in place. Never had a problem ?Yep so I hear.. bunch of bananas on top.. I was worried about the belt as I have no history for it then did some research and discovered that although it is technically an interference engine the most likely damage after a snap at high revs will be bent ouch rods which don't even need head off to replace.. The belt can wait till I've got spare dosh for the timing keys.. looking forward to that weekends work
Yes they do have some that'll have you falling about.
Another one to catch you out is that it is illegal to wash your vehicle except in the garages & stand-alone car washes. That includes in your own fence & gated property !!
You can bump start an auto---must go over about 30 MPH thoughA jump start can spike the ecu of any modern vehicle if it isn't done right.. The answer is to do it right. Jump starting is always the method of choice to start a car with a flat battery regardless of the cause of the flat. You can't bump an auto anyway and trying to bump start a 3.5tonne vehicle is a pretty much non starter.. excuse the pun.
It is actually illegal everywhere in Spain. It comes under Medio ambiente. Environmental regulations. Any & all water used to wash vehicles etc; has to be contained ,filtered & reused. To prevent chemicals leeching in to ground water. I don't know why when you see what they spray on the fields & some of it strips galvanising from your fences ! They just don't do anything about it up your way probably.Not illegal in our part of Spain - I thought Murcia was more relaxed than Communidad Valenciana, but obviously not in this case!
I was meaning a bump start.As my last post above....a jump start or fully charged battery.....how can one strip the cambelt but the other doesnt.
