dawsey
Contentious, yes I know. I can almost hear the cries of derision and snorts of laughter…
But - the firm conclusion we have come to after living in the van through four seasons on the continent, is that for any camper, roof mounted solar panels are actually near-useless and are just a waste of money IF you have a decent B2B and can hook up, and you do actually routinely use some power via a decent Invertor as we do.
Hear me out….
First - our setup. I wanted us to be self sufficient. No need for hookup as we’d be full timing in France through winter with few campsites open, so staying on free aires. I installed as many panels as I could fit onto the roof. This was 600W of roof solar (6x100W) connected in parallel, combined 25/50A MPPT and B2B, 200ah of Lithium and 2000W hard-wired invertor, all integrated with the existing Schaudt Elektroblok systems. Van is a 21yr old Hymer A class. The only change to the standard vehicle electrical architecture was an uprated alternator (150A) to ensure 80A could be delivered at idle.
All has worked perfectly for a nearly a year. The only part of the system which isn’t really useful, and actually just isn’t needed is all the solar panels. With a decent B2B, the solar panels are, in fact, not really needed at all.
So why is the roof solar useless?
Summer
Yes you can get great output from the panels in full sun. I’ve seen 27 Amps at 20V, 540 Watts. The 6mm CSA copper cables from the collector to the MPPT were actually getting hot. At one point I was just about able to run the similar rated power a/c unit just from all that lovely solar power.
But - it’s really not a good idea to park a van in full sun in a continental summer. It heats up and we couldn’t get it cool enough to sleep until midnight, running a high power extractor continuously. So you seek out shade. We would always park in the shade of a nice big trees to AVOID direct sun on the van. Then, of course the solar panels give very little, my 600W gives about 50W even with the clever MPPT system. The panels, in shade, become effectively useless.
With a 50A B2B, you only need to run the engine for 10minutes to put the same amount of charge into your batteries.
We found that when parked in the shade we could never get sufficient charge even from our huge roof mounted solar array to recharge our batteries. After four or five days they would be discharged, just a couple of days more than in winter…
If wildcamping/free car park/aire with no EHU, even in summer we still fully discharge our batteries and had no choice but to run the engine or drive to the shops.
If on paid aire or campsite it’s just better to park in the shade and plug in EHU (you can run engine to recharge batteries and save the EHU cost but you may well consume more diesel than the hook up cost!)
Winter - usually on free aires
The sun is always so low that there is almost no effective charging, but the electrical energy use is higher (lighting, being stuck inside more etc). The panels contribute so little it is laughable. If not moving every couple of days, if no EHU you have to run the engine. We got in the habit when stationary of running the engine for up to an hour every day just after nightfall to both recharge the batteries and help the van build and retain sufficient warmth for the night. The solar panels in full sun would give a peak of maybe 4-5A on a very clear winter day, but you would have to be completely out in the open and nowhere near a building or a tree. In reality, the low sun was usually obstructed by trees or buildings and we averaged maybe 1-2A during the short day. Conclusion, in winter, our solar panels were absolutely useless.
When driving, a good 50A B2B will so rapidly charge lithium batteries, it again rendering the solar panels pointless. There were many times when we drove for an hour and it was cloudy so I would isolate the solar (which might have been giving 5A) to make the integrated MPPT/B2B auto switch from 25 to 50A just to charge faster.
Conclusion - if you have a powerful B2B, and you do actually make use of an invertor and consume some power using 240V appliances (yes I know this isn’t everyone..) then heavy roof mounted solar for a camper is just not worth the money as it really is effectively useless, summer or winter. It’s way better to park in the shade and connect EHU summer, and, if no EHU is available, in winter you will find that you have to run the engine every day no matter how many panels you might have (you also benefit from all the lovely engine heat, so little is wasted).
Looking at our experience, I concluded that the only way to get real utilisation and power out of solar panels in a continental summer without turning your van into a dutch oven is a collapsible suitcase/remote panel set up, where you can set up and arrange a remote array of panels and point them toward direct sunlight, with the van remaining safely parked in the shade. This would work, but of course you’d need the space, so you are really limited to campsites.
Right, I will get my popcorn……
Hear me out….
Summer
