Been doing Continental travelling for the past 10 yrs now.
Didn't know about it then and am not in the least bit worried about it now.
However IF you are worried then buy the necessary kit!
[/B]
agreed....if it worries you then it only costs a few quid for the lead and tester......and nobody will call you daft for using it.
its all down to personal choice :thumb:
as others have said....lack of an earth is far more important and theres nothing you can do about that !!
Oh no there isnt !!!!oh yes there is lol
http://www.screwfix.com/p/earth-rod-3-8-4ft/28044
for an earth spike to work there must be an earth return path to the substation
if the hookup post has no form of earthing whatsoever, then there is no earth return path.
a properly installed earth will be connected at the post and the substation.
look at any overhead (pylon) power lines......there is no earth wire, as the earth is connected to the high voltage transformer at the substation.
there are various methods to earth a supply...one being the TT system were there is no earth conductor supplied by the electric generating company.Don't know enough about electricity to dispute what you are saying but why do they sell earthing rods.Incidentally I have two because of slight tingles through chassis when washing the fiver on hook up without earth, I have never used them because I have always managed to find a post with earth since.
I was informed that this occured due to it being essential that the 240/110v transformer in the 5'er is earthed, don't know the technical reasons.
This incident caused me to discover that my tester does not show a lack of earth whilst showing reversed polarity, which I ignored then but always now correct in order to be able to check for an earth.
Expensive but easy and safe :thumb:
http://www.johnscross.co.uk/products/caravan-motorhome-polarity-change-over-switch.html
Tester only if you want to check
http://www.johnscross.co.uk/products/caravan-motorhome-mains-polarity-tester.html
Peter
agreed.....a pair of basic LED's, which by their nature only work one way round, a two way, two pole switch and a plastic box.....£5 for the lot.Has anyone tried this. Seems very expensive for what it is.
It's a problem with these forums.
If you are doing a job, do it properly. A tester plug costs nothing, a cross over adaptor costs nearly nothing. So buy them both and use them. Just one minute of your time when you hook up and you'll know that you are safee.
the system is earthed at the companies transformer and relies on the ground to return the current if there's a fault in the house.
as there is no earth cable coming into the fuse box it needs an earth spike connected to the fuse box to take fault current into the ground and thus back to the transformer.
in a TN-S system the company provide an earth cable from the power transformer to the fuse box in the house and all electrical protective circuits are connected to this earth wire...negating the need for an earth spike.
the problem is....which system has been used in a French hookup post ?
if there are overhead cables theres a very good chance it is a TT system
if it is a TT system then an earth spike will work...but how do you know its a TT for sure.....or just an installer who couldn't be bothered to fit the earth in a TN-S system
If you have reverse polarity, it means that the electricity is connected the wrong way round. This means that the MCB is on the neutral and not the live wire,[HI] removing the protection.[/HI] I always check the polarity and have a converter in the van. Better to be safe than etc.etc.
If you are doing a job, do it properly. A tester plug costs nothing, a cross over adaptor costs nearly nothing. So buy them both and use them. Just one minute of your time when you hook up and you'll know that you are safe.
Hi Hilldweller interested in your comment about buying a cross over adaptor do you have an example please? Thanks
An MCB is an overload device.. a modern day fuse.. If the neutral and live are reversed it will still operate as designed.
as explained eloquently by papajohn with his light bulb example, reversed line and neutral will not affect the operation of any appliance nor compromise the operation of an MCB or an ELCB .. ( Earth Leakage Circuit Breaker )
Link Removed
Link Removed
Link Removed
I just bought the plug and socket and made one up with a foot of mains flex, you connect E to E then L to N and N to L. Mark it carefully CROSSOVER. If you detect wrong polarity just put this in-line outside. Fit at the post end then you automatically handle dead cables.
E---------------------E
L---------------------N
N--------------------L
