reverse polarity
POH
Pilote 740c
5 years
as above which end do I alter to make this reverse polarity. thanks
Is there someone out there wot knows about this stuff who can confirm this: reverse polarity on AC isn't really an issue for the kit it's operating because its Alternating Current which actually pulses backwards and forwards metaphorically speaking, thus reversing the polarity 50 times a second. Where it does matter is knowing that the red cable will bite, but the blue or black one probably won't. ( I say probably because of the double switched light at the top of the stairs - sneaky bastard is that one). Also: polarity matters in the UK because typically we use single pole isolators with fused appliances, and not so much in France because they use double pole isolators.
That is correct.
UK MHs also mostly have double-pole MCBs, and according to the latest regs that's what they should have. Single-pole MCBs are only found in older MHs and some self-builds.
Didn't know they had updated the regs and got sensible.
I seem to recall they had RCD protection before it became common over here
Maybe in houses but not Motorhomes & Caravans. A 2002 Hobby caravan I bought in Germany didn't have nor did the 2008 Hymer I bought in Belgium but I did fit them myself.
Reversed polarity is one of the many things we knew nothing about when we first went abroad in a British campervan in 1990s so didn't worry about it. Then they invented the internet and forums so I had an inkling of rev. polarity but didn't worry because by then we had an Adria which could keep us safe if there was a problem. In a week's time we are back to a British conversion. To worry or not to worry that is the question ...think I'll go with autorouter's knowledge and not worry:cool:
The problem, such as it is, arises because the UK-style domestic systems require the polarity to be correct as you say, but then you cross the Channel to where the polarity is not important, and plug your UK MH into a European system. That's why MHs are now wired with an RCD and double-pole MCBs. But there are older MHs and self-builds that aren't.
When I installed some extra sockets in the mh, on testing I got a reading for reversed polarity. So unscrewed the socket and that was fine, further testing revealed the whole 220v system was factory built with reversed polarity!
Having correct polarity is vitally important otherwise your fridge would heat, your oven would cool, you vacuum cleaner would blow and your leisure batteries would discharge.
The reverse polarity adapter comes in useful occasionally. If I burn the toast, I just plug in the adapter, put the toast back in the toaster until it's untoasted, then put it all back again and try again.
