- Apr 1, 2024
- 8
- 0
- Burstner 690G
- I'm a newbie
Id price that cluster first, that will tell you how much grunt you can use.I think Ive worked out how to do it. 1. Remove light cluster. 2. access top set of bolts next to that. 3. Attack the lower bolts from the underside using a right angled screwdriver. However I am really struggling to remove the light cluster. Burstner's instructions are pretty vague - Insert a 'flat tool' into the notch and carefully level off the housing. Mine appears to be stuck fast and Im concerned that if I put too much pressure on it, the cluster will break. Any thoughts?
