Replacement Kitchen Water Tap (1 Viewer)
Feb 13, 2023
188
61
United Kingdom
Bessacarr E695
Hi all
If I wanted to replace my aging brass/gold kitchen tap in my old monstrosity of a Moho just to try and modernise things a little, is there something special i should be looking for, or will any kitchen tap do?
Cheeers all :)
Nov 4, 2011
6,248
42,917
Uk
Depends what type of water system you have, micro switch in taps or pressure system also what size hole in the work top.
Sep 25, 2023
724
913
Swift Sundance 590RS
I believe you can use a Micro switch operated tap on a pressure operated system but not the other way round obviously. The Pressure operated system relies on a drop in pressure when opening the tap to start the pump. This would happen on eith type of tap, just means the microswitch wires are redundant if thats the model you choose.
Sep 26, 2013
4,233
5,256
Market Rasen
Self Build
Since 2003
If it’s a pressure system then any tap will do, I’ve used one we took out of the kitchen a few years ago. You just need to get the correct fittings from somewhere like Magnum Motorhomes
