McLouis Fusion 331 - the bung in the water tank is the original T-bar type but it doesn't expand quite enough to bung the outlet pipe! So it drips!
Thanks McLouis, your usual design genius.
The outlet pipe does not seem to be damaged (split).
Can anyone recommend a replacement? I'd rather not go for original - as it's pants. There's lots of bungs for boat transoms (whatever they are) but I'd rather go for one designed for a water tank as the materials are likely to be more suitable.
The existing bung expands to very nearly 25mm diameter. So the bung needs to expand to a little bit more than that!
Thanks,
Dave
Thanks,
Dave
