Renault master 2007 lunar H622 near side rear indicator inop all other indicators work will occasionally work had a look 2 wire 1 white 1 yellow can’t see were loom for lights is on rear any ideas. Thanks
Start from the light assembly and work back, checking continuity as you go, but usually a bad earth or connection at the light assembly would be my first guess,
