• Well done, you found us. THIS IS THE NEW SERVER
Removing Transit Front Seats. (1 Viewer)
AXO66
762
4,715
Pembrokeshire
Chasson 510
Looking to remove the drivers seat of a Mk8 transit based Chausson.
Can anyone give me the heads up on the type of socket “screw bit” needed to unscrew the seat and the approximate size so I can order a set with a good chance it will be included, please.
I want to have a good look at all the wireing that seems to go to the engine batterry, and to be able to replace the battery when the time comes.
Mar 16, 2010
3,065
31,524
Carmarthenshire
In between
Since 1988
Ours comes out with Alan keys Hex 5...so I have just been informed
andy63
4,672
15,018
south shields
None
since 1990
If it like mine its a torx set you will need.. Can't say for sure which one but the standard sets will cover it.. You will need two sizes.. One for the 4 bolts securing the seat slides and if you want to lift the seat clear of the plinth a larger bit to undothe seat belt fastening..
Andy
thebriars
1,149
2,182
Teesside
Since 1990
The seat is b$$$$y heavy! The passenger seat has the habitation battery and the driver's seat the engine battery. Very difficult to see where any of the wiring goes. My Benimar was already wired for 2 habitation batteries, even down to two vent pipes, but a very tight fit to get them both in.
I keep a cheap socket set from Lidl in the mh, and this came with all the required Torx sizes to remove the seat.
AXO66
AXO66
762
4,715
Pembrokeshire
Chasson 510
Thanks for the quick replies
Will look closely to see if it’s torx, and use my current small ones to guess the size I need.
(Chausson only have one battery under passanger seat, and i have heard they do not recommend putting another in. Wonder if that's to do with ECU charger power or only one venting hole in floor,)
thebriars
1,149
2,182
Teesside
Since 1990
The Ford chassis is the same spec. Have heard this one before about Chaussons. Presumably the Chausson also has solar power?
AXO66
AXO66
762
4,715
Pembrokeshire
Chasson 510
Not ours, we manage with one battery, so far!
friend just got a new one with solar and had a second battery installed, although aware of chaussons view.
Ours is a 210 on a 2015 year built outfit with a CBE electric system.
I Can just get our battery out with a lot of wriggling and turning on it‘s side.
have seen someone on this site put 2 a ford , in by placing them across the vehicle, ours is placed front to back.
May 29, 2013
2,631
19,528
Tyneside
Chausson best of Flash 10
Several years now
We have two 110ah leisure batteries fitted under passenger seat, retro fit by me, but been in a year and no problems.
