- Dec 17, 2019
- 1,132
- 2,057
- Carthago Malibu
- Converted caravanner!
Gadget John on YouTube had issues as a result of a remap recently
Who did he use? Can’t watch at the moment.
It's better to translate than for me to paste as you'll see the format and graphsIt’s in Dutch!![]()
The take away from that tune is there's no point going much over max torque at about 2000rpm/100ish bhp so the marketing guys fixation with bhp is a bit of nonsenseIt's better to translate than for me to paste as you'll see the format and graphs
2.3 M-Jet 16v 140 PK 6MT Euro 6D Chiptuning - Squadra Tuning
Opnieuw zijn de emissie-eisen aangescherpt en worden autofabrikanten gedwongen steeds meer uitlaatgasreinigingstechnieken toe te passen. EGR systemen, passieve en actieve..squadra--tuning-nl.translate.goog
I had a 2.3 fiat done in Cornwall , drove around ok. Took it to the Alps and black clouds followed me. So bad gave up, drove back and had it removed. Believe it or not I was told we didn't expect you to go that high under load.! Driven Merc ever since.MOTs only test emissions at idle. Euro6 requirements test the vehicle under load. I think the Euro6final test puts the vehicle on a rolling road and takes a couple of hours for each of dozens of runs. Passing an MOT isn't the same as being Euro compliant.
The 130 to 150 has a number of different parts from turbo to cat/doc/dpf gearbox (manual, the comformatic has same M40 as 150,180)and brakes the 180 has the same vvt turbo, again i was told only map was different. In the same vein it was the VW salesman that said it was only the map, who believes salesmen.Are you sure of that? I thought the Fiat one was considerably more than just a remapped 150, different turbo etc. no idea about the VW but I'd guess that would be similar.
I think I read about a different crank shaft as well.The 130 to 150 has a number of different parts from turbo to cat/doc/dpf gearbox (manual, the comformatic has same M40 as 150,180)and brakes the 180 has the same vvt turbo, again i was told only map was different. In the same vein it was the VW salesman that said it was only the map, who believes salesmen.
Going into limp mode, I can understand. I'm not sure how mapping could affect the electrics though.Well just to add my tuppence worth, my first motorhome was remapped prior to purchase by previous owner. It was on a renault base vehicle. It broke down three times blowing the engine master fuse. Had several faults of going into limp mode, too many to count. Had to go to Renault commercial workshop as motorhome garage couldn't diagnosis fault. Renault commercial reinstalled original mapping, as they said that was at fault. So be careful who maps your vehicle, use a recommended company.
You dont obviously tip the tester enough, Joking aside it is/was the correct way but many testers dont want the hastle of potentially blowing an engine up i guessSince when?
Every diesel I've had has been tested at high revs..... Not constant but a 'floor it' to around 4000 rpm for a second or two.
Usually asked when/if the cam belts been changed as if it snaps during the test they are liable for repair.
Do i read it that the previous owner did the re map himself rather than going to a reconised company. Only asking as i am thinking of getting 2007 base Renault remappedWell just to add my tuppence worth, my first motorhome was remapped prior to purchase by previous owner. It was on a renault base vehicle. It broke down three times blowing the engine master fuse. Had several faults of going into limp mode, too many to count. Had to go to Renault commercial workshop as motorhome garage couldn't diagnosis fault. Renault commercial reinstalled original mapping, as they said that was at fault. So be careful who maps your vehicle, use a recommended company.
I can’t honestly see how a remapping can cause a main engine fuse to blow, performance faults yes ;Do i read it that the previous owner did the re map himself rather than going to a reconised company. Only asking as i am thinking of getting 2007 base Renault remapped
From 130 to 150? Wouldnt be surprised. Wish i knew then what i know now. But when i tried to order to my spec found out not possible as model was withdrawn and had to search forcourts for unsold dealer spec.I think I read about a different crank shaft as well.
