- May 26, 2016
- 1,750
- 6,628
- low profile Elddis
- 40 years on and off
Why isn't the engine tuned for optimum performance by the manufacturer? is the obvious question here.
Differing grades of fuel and environments apparently means they have to do a one size fits all approach.Why isn't the engine tuned for optimum performance by the manufacturer? is the obvious question here.
Question answered here. And looks to be the best answer I can find.Why isn't the engine tuned for optimum performance by the manufacturer? is the obvious question here.
Money they can see a van with higher bhp for more.Your answer in in post #34
section
The problem with the ECU’s original software
The only thing I would warn you about is the clutchWhen I was thinking about the remap I did read what I could see on the forum.
this post came up in April 2015. So shows I was looking and it was one of the posts of many saying they had good.
results that made me consider it some more .
done now but as he told me can also be undone.
so far as insurance goes he said it was upto me to inform the insurance company.
but the remap does not include information like whom when where .
it’s not a racing car. But I may do it for piece of mind .
I will update this thread when I know .
If that is the case surely an after market re map without the factories additional changes would throw up issues down the line?When manufacturers offer what appears to be the same engine with differing power and torque outputs, they are not simple mapping upgrades, common internal changes include and are not limited to the oiling system, pistons, compression ratio, injectors, turbo along with the associated electronics.
Any power or torque increase claimed without the use of a dynamometer or rolling road are at best theoretical.
they do the work either at your home or work I guess the answer No
it is not exactly a sports car that needs as much as one can get out of it. So there for does not need any additional parts
hence no need to be tested on a rolling road.
if additional parts were fitted like a bigger exhaust and hi tech air and carbs ect I expect I would need a rolling road test.
Still doesn't answer how they get the figures
The guys that do a generic remap at your home download the map from a company that have actually had the similar generic vehicle on the rolling road. So a fiat ducato van is tested, giving base figures and then slowly adjusted to reach the sweet spot you are looking for. It does not however take account of a vehicle being fully loaded all the time. You end up with a theoretical torque figure which is rarely metStill doesn't answer how they get the figures
My 2.8 has been mapped and as we have only owned it a short time have not taken it on a long trip. It had a new clutch fitted about a year ago by a reputable company as we have the receipts to show but a couple of times whilst giving it a bit too much welly I thought I could feel the clutch slip and wondered the same thing. It pulls away like a train, the acceleration is outstanding but I just worry there is too more torque for the clutch to handle. I will be watching with interest when we get away later in the year.Wasn’t there a thread about clutches slipping after having the mapping done
Had the car done but wouldn’t do the motorhome, as it pulls slovelly as it is![]()
So if one opts for a Ducato 160hp or even a180hp over the standard 140hp are we just paying an extortionate amount for a for a Fiat Factory remap or are there other modifications involved as well such as turbo etc?
Interesting, thankyou. I wonder if that is the case for the new 2022 Ducato 140 vs160,180 which I believe are now the Peugeot unit.the fiat 150 & 180 are different to the 130 , differences inc turbo / pistons & cam
Wasn't that the 2.0 model with a wet cam belt????beware remapping the ford puma engine as fitted to some peugeots. There was a major issue 3 or 4 years ago with the mapping from the factory. Under load, they can self destruct, so peugeot did a huge recall to re-map the engines to hopefully solve the problem from happening. Re-mapping them to up the power output "could" easily put the fault back on again
Heavier vans with smaller engines look good on paper for economy, but tend to be lacking in the power department. Increasing torque at the motor though squeezes that extra power through the same undersized clutch to the gearbox though. Push it just a tiny bit too far and suddenly that clutch will soon complain and let go.
Did you use eMotion?Here is an update as they were in the area did it now less. £ 50. As they were also making a saving
now
BHP WAS 110. Now. 144. plus 34
NM. WAS 300. Now. 390. Plus 90
hope this will make a difference.
engine check no error codes recorded now and they can’t see any in the past.
so all good I hope and all within the safe parameters .
If it’s definitely the puma engine then the options are endless as this is fitted to land rover defenders. The engine ecu “should” be the same, ask on a Land Rover forum for anyone with a NANOCOM. If they can read it through the obd port then there are a few downloadable files to upload to the ecu. Just make sure you take a backup first otherwise you will have a doorstop!Also the 2.2 motor is the Ford Puma engine, I have one in my small van.
As recommended do a google search for Celtic tuning they have remapped all over the country.Had our 2004 Burstner A747 5t 2.8 Jtd 127hp remapped years ago at one of the shows.
It was a totally different vehicle and became an absolute pleasure to drive.
Honestly couldn’t tell you if the mpg increased but it certainly wasn’t any worse.
Never had any problems with the clutch or anything else.
Recently changed to a 2016 2.3 Multi-jet Fiat Rapido 3.5t which I would like remapping.
I would like to know if anyone here has experience of a company around Wigan or Preston area who they could recommend.
As recommended do a google search for Celtic tuning they have remapped all over the country.Can anyone recommend a company within the Derbyshire area.
Celtic tuningDid you use eMotion?
