Reich Power Jet 25l per min????Hymer (2 Viewers)
Jul 26, 2015
300
200
Devon
Hymer
since 1999
The water pump on our hymer is not very powerful so i replaced it with a Reich 19l twin pump but still no real difference, can anybody recommend the Reich power jet 25l min please. Many thanks
bluesurf989
Jul 26, 2015
300
200
Devon
Hymer
since 1999
Thank you everybody. I will go out and try this shortly and let you know how i get on(y)
Sep 17, 2017
6,207
11,828
Birmingham, UK
A-Class
My van has a 7 l/mini pump and that's plenty! More is just going to mean more power use, more noise, more chance of leaks, and refilling the tank more often.
The other factor is how much pressure the pump can push. A high flow pump might produce poor static pressure, so narrow pipes and lots of junctions and filters might make the flow reduce to a trickle. When a lower peak flow pump that has a better pressure would push more water in a motorhome's restrictive pipework.
Jan 1, 2019
775
1,445
Pembrokeshire
Hymer B704 PL
Since 2017
I changed my pump to a Reich 25l Power Jet Plus. Definitely increased the pressure. I now carry a spare just in case.
