Regeneration fiat
The typical regen rate I have seen reported is in the 3 to 400 mile region. I would be happy with long intervals if your dpf differential Sensor is showing sensible values. It shows it is not producing bucket loads of soot to deal with. The injector deviation values will be interesting, I suspect they are low (Ie good).
Have you got a clean exhaust pipe?
Thanks for your replies - it's great that we can all help each other on this forum.
At the moment my exhaust is clean and if it's averaged 350 miles between regens it seems to be working OK at the moment. I'll start using the DPF app to keep an eye on things but it's on SORN now so perhaps we will pick up this thread again next year when we all start to use our vans properly again.
My previous van was a 2008 X250 but did have a cat so perhaps yours had been removed - they were often the target for theft. Diesels were so much simpler before DPFs🤔
I wondered this so, when the clutch was renewed at a Fiat Professional garage, (too complicated without a pit at my age) I asked and was told that there was a few of the early X250's that had neither? :unsure:
An 08 certainly wouldn’t have DPF , they were much later, and potentially an 08 motorhome is probably an 07900247793 Fiat, due to build times. That is certainly the case with mine. My 09 has two cats, well did, a pre cat, and a cat.
