there one in dorchester bp The Grove
DT1 1XU Dorchester
United Kingdom
DT1 1XU Dorchester
United Kingdom
Filled up there last Friday. Its a really slow pump. paid £0.79pplIn three years I've only had one girl come and check, at the Asda garage in Derby. As soon as she saw my bottles in the cabinet she smiled and walked back to the kiosk.
No problems
I use just one Gaslow and have a calor as a spare. Have done 18 months like that and never used the calor!
I never fill with diesel and lpg at the same time for this reason. They won't know you only want 12L until you've filled. They can't suck it back out.They will, or should, know if you fill with diesel at the same time.
Anyway does anyone on with an LPG-powered engine stop for 12lt of LPG?
The pump is the first on the middle isle and can fill from either side and if your diesel filler is the same side no moving Denise will get prices laterAnd let me know where the pump is!![]()
From experience I think that the Gaslow bottle gauge is not entirely reliable! I always get less in than I was expecting. The only reliable gauge on my Gaslow system is the the red flag on the auto change over valve..........I recently fitted a Gaslow bottle and external filler. Kept a Calor gas bottle for now as it was nearly full. Have adopted the fill up when passing a LPG garage. Popped into Morrisons in Enfield yesterday and only managed around 3l @79p/l to fill up (£2.50). Thought I had used more than that in my last few trips
myLPG app is brilliant and can also warn when no LPG in stock. Plan on travelling to France later in the year so will be handy too.
Same for me.I use just one Gaslow and have a calor as a spare. Have done 18 months like that and never used the calor!
Same for 12 years.
Same for me.
Been hauling around an unused full Calor gas bottle since 2019.
Part of the deal when I bought the last few vans. My system is to use only one of the bottles until empty, I then have a couple of weeks at least to fill up without problemsIt does make me wonder why people fit expensive double bottle and auto changeover systems.
He has already filled many others before mine. I think he knows what he's doing. His meter measured 12 litres (6kg bottle). Sounds about right.How do you know you've not over filled it?
We are all paranoid belt and braces people with a plan b in case no LPG available.It does make me wonder why people fit expensive double bottle and auto changeover systems.
Joe put it in wrong! It's 79.7p/l. I know it's only 0.2p but every little help, LOL!Gas at Morrisons Sittingbourne 79.9p
We use an 11 kg in 3 days in winterIt does make me wonder why people fit expensive double bottle and auto changeover systems.
We had just an 11kg originally but didn't do more than 3 week trips so having a Calor as a backup was okay, we then got a Chausson that only took a single bottle so the Calor was ditched but again we only did short trips. When we changed to PVC our single bottle was all that would fit, however our 2 subsequent ones took 2 bottles so we had 11kg and snaffled a cheap 6kg Gaslow one at the Peterborough show to go with it as we were then doing longer trips away. A couple of years later when the opportunity arose to get a nearly new 11kg locally I did so and sold the 6kg, as we were doing even longer trips and in cooler weather it meant we had sufficient to keep us going without having to be concerned about topping up when the needle dropped.It does make me wonder why people fit expensive double bottle and auto changeover systems.
Our way of holidaying has changed, instead of moving on every day, we can stay up to 5 days in one spot so having 2 x 11kg cylinders means we don't have to move if we don't want to if one is getting low, if I had to buy the system again we might consider just having one but the convenience and lack of worry by having 2 would probably mean we'd still have 2.
Well if you will try and take the canopy off what do you expect.In three years I've only had one girl come and check, at the Asda garage in Derby. As soon as she saw my bottles in the cabinet she smiled and walked back to the kiosk.
No problems
Yup weather and time of year makes a difference, when we went in December down through France it was below freezing during the night and not much above it during the day so we used a fair bit of gas due to having the heating on, then once we were in Spain even though the days were warm as soon as the sun went down the temperature plummeted many times to just above freezing. Driving back up through France in February was blooming cold too!Depends on weather I suppose but we did 10 days without moving at the Le Mans 24 hour race last year. We have one 11KG gaslow. Cooking and showers and it was plenty. Calor there as back up but as always not used.
We tend not to do much travelling in the winter. Prefer to be curled up round the wood burner.
What a memory LennyWell if you will try and take the canopy off what do you expect.![]()
On a Motorhome I would personally recommend you go with a system that can have an external filler point.Thank you for all your advice and comments, they are much appreciated. I’m still not decided but will probably go with a Safefill and a Calor back up.
BasildogI know it's possible as someone had fitted to my old van but is it permissible to have a tandem setup. Underslung tank and bottles, switching between either? The benefit being not having to move van to filling station when bulk tank runs out Looking at options to maximise winter off-grid stay with Alde. Also cont find a tank larger than 100ltr at the mo. Anyone know of larger capacity available Ta. P.
