If you are worried about being challenged about filling gas and diesel at the same station
Simply fill diesel at one service station and LPG at another
Hi .I too am considering Safefill as an option. However for the past 6 weeks since lookong both Safefill, and other suppliers seem permanently out of stock. Any ideas where I can get one ? Thanks
Don't understand?? Morrisons don't care how it's burned. Professionally installed tanks are used for either propulsion or domestic use.Yeh but you can’t run tanks on a Diesel engine so I’m stuck in trying to pull the wool over someone’s eyes.
The only time I have been asked why I am filling an obvious diesel with gas, I told them it was for on board generator ( which does not exist )Yeh but you can’t run tanks on a Diesel engine so I’m stuck in trying to pull the wool over someone’s eyes.
I think you are overthinking this and making it a problem. I only have one problem with supermarkets and that is which one do gas, Morrisons mostly do but the others do not. I have never been refused as they are all happy when you plug into a socket on the side.. trying to fill loose and obvious bottles would be a no no, same as trying to fill fuel cans over two gallons or the wrong type.Would the filling point be an issue if it’s fitted the opposite side to the fuel filler, would that be a dead giveaway.
