Recurring punctures on Brompton bike: how to solve the issue? (3 Viewers)
RandallC
1,242
3,489
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Had issues in the past where the rim profile was sharp and cut the tube on the inside.
Cured with a couple of layers of insulation tape to cover the bare metal
Sep 17, 2017
5,678
10,646
Birmingham, UK
A-Class
I'd change to tubeless tyres if you can.All my MTB's are and no punctures for years
I agree that tubeless is great, but the Brompton rims aren't tubeless compatible and there aren't any skinny 16" tubeless tyres either.
Apr 26, 2015
2,864
7,067
Ottershaw
Hymer S820
First motorhome May 2021
Apparently it is possible to put Tanus airless tyres on a Brompton but rolling resistance may be increased.
Ridgeway
3,690
6,268
Lausanne
NiBi Arto 85E
Check the inside of the tyres for splits or cracks, I had several punctures on a motorcycle, eventually tracked it down to a small split on the inside of the tyre, constant flexing caused the split to nip the tube.
Think he changed the tyre as well as the tube.
Dec 16, 2017
1,232
2,527
Almuñécar, Spain
Low Profile - Globebus T7
Just squirt a sealant into the inner tubes - Joe's, or Slime for example, pump up and forget about it. Then small punctures self seal. http://www.joes-no-flats.com/ or https://uk.slime.com/products/bike/sealants/ When we had the activity company here I had 18 mtbs out (before tubeless tyres were popular) regularly in thorny conditions and after we started using Joe's we went from 3 or 4 flats a day to 1 or 2 a month - so I know it works in tubed tyres as well as tubeless.
Sep 12, 2016
2,287
5,075
Chesterfield England Tellus 3
Lunar Roadstar 800
6 years
Lots of answers but
1/ check the inside of the rim so you can be certain the spokes are not fouling the inner tube
2/ Change the tyre for a puncture resistance one and a heavy duty inner tube
I have recently done this on our bikes with good effect
Jul 14, 2019
392
553
Hymer MLT 570
Our 1st Motorhome
I was fed up with getting punctures, so thought I'd try some tyre liners (Zefal), and they've been great 🤞. They sit in between the inner tube and the tyre, to prevent thorns etc getting into contact with the inner tube - well that's the theory anyway!
Parrot Face
Jan 22, 2012
1,465
2,241
Wigan
Knaus Sun TI 2012
Thanks everyone. Went to cycle shop in Javea, very helpful. It all came down to fault on pump pressure gauge. Pressure in tyres was low and wife's seating position wasn't helping. Pressure increase seems to be working. Got a new gauge.
Oct 29, 2008
5,118
6,111
West Yorkshire
We put Schwalbe Magic Mike BMX tyres on our folders as they have kevlar reinforcement and a chunkier tread like a mountain bike. No punctures since and far better handling on slippery bends and corners.
Feb 14, 2021
3,793
8,168
Milton Keynes, UK
Burstner Lyseo 727G
Can you get a solid tyre for the Brompton? ;)
Apr 30, 2020
444
6,361
Hartpury, Gloucester, Gloucestershire, UK
Bailey Autograph 796
Reading this thread is there the opportunity to run tubeless?
If not, Not exactly for a folding bike, but there must be something like it available…..I run one of these in my mountain bike rear tyre (in winter) to allow me to run lower air pressure and not pinch damage the rim or casing. My bum only has so much inherent suspension before my heft is transferred to the rear tyre. I have to say that it works well.
Tyre Insert
Jun 21, 2020
251
395
Huntingdon ish.... the rundown backwater
since 2007
I'm on the tools and most of my advice has already been covered..... Marathon tyres usually used on the Brompton's only usually puncture through the sidewalls assuming the tyre tread area is not too worn out or in decent condition. If the tyre is clear of thorns and debris then nine times out of ten the rim tape is damaged or you maybe pinching the tube on reassembly. I usually replace the tape with Velox stick on tape if they look dodgy. Sadly there is nothing in this size tubeless unless you consider Tannus tyres. I am doing tubeless set up's week in and week out now, the tyres are more mature now and there are some terrific sealants out there too.
Aug 22, 2022
140
330
Of no fixed abode
Bedford MJ AWD
What type of Moho is that in the background?
I live full time in a 1989 Bedford MJ. Click on the Instagram link in my footer and you can see a bit more of it.
Mark
Aug 22, 2022
140
330
Of no fixed abode
Bedford MJ AWD
I believe it was one of the twelve Ptarmigan communications trucks. I didn’t know when I bought it but a friend who served in Germany recognised it and I Googled to find out more.
Ridgeway
3,690
6,268
Lausanne
NiBi Arto 85E
Excellent 👍🏻 you’ll be fine with regular tyres and correct pressure. You may get an odd puncture here and there but have to say I’ve only had 1 puncture in 4yrs on mine and it was most of the time on slick (Kojak) tyres.
May 19, 2014
217
443
Keynsham, Bristol, UK
Pilote
If the punctures are around the valve I've had that problem and you need to take great care to seat it properly to avoid pinching, especially over rougher terrain.
Sep 17, 2017
5,678
10,646
Birmingham, UK
A-Class
Marathon Plus tyres came with my Brompton. As mentioned, they were glass magnets. Through the tread. They were also heavy, slow and really hard to get on and off the rim each time. But Continental Urban Contacts don't seem to pick up glass at all. No punctures on a couple of years (although I'm mainly using the bike for errands, shopping and van duty now, not commuting).
Dec 6, 2019
16
23
Autosleeper Kingham
Totally agree, used to get punctures on our little foldups especially from pine needles on forest tracks ,got slime from halfords we never got another even after 5 years. One bottle did the four small tyres. It's easy to squirt in with Schrader type valves but when we go bigger bikes with presta type it was more difficult. I now get the tubes with the stuff already inside 😀
