just wandering
We have given the insulation of our van allot of thought as its one of the most important parts of the conversion.
Its nearly as important as choosing the right size fridge to fit the beers in
I have been reading up on all the different types available and have also seen what the main manufacturers use.
We have taken on all the valuable comments from the forum and finally decided on....
Broken Link Removed
I intend to stick this straight on to the vans interior shell. This will form my first layer of insulation and vapor barrier.
This is the sort of thing the big manufacturers use such as IH and Globecar but a little thicker at 10 mm.
On top of this i will be applying a second layer of Kingspan / Celotex type material. This will be a minimum of 25 mm and in some areas around 50mm. This will be stuck using a high temperature adhesive. Some areas of the van are very hard to insulate using the above products so i will be using sheep's wool and gun applied expanding foam![]()
Hi Ralph-n-Bev.
This is also an area i've spent so much time on, researching, researching and even more researching. I finaly came across Happily Homeless on youtube and was interested in the materials he was using, but a bit pricey for me. (see video)
Then I came across RattleMatt on fleabay: http://www.ebay.co.uk/itm/300719999472?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
I figure I'd need 3 of these, 300 sqft/28 sqm - plus the bubble foil.
Then I found this post with the link to harrisons trim supplies. I've had a look and I think this might be what i'm looking for. It seems to combine sound deadner and foil insulation into 1 material. Would that be correct?
How did you find it working with this material, was it easy enough to apply?
Cheers,
Jack
