I couldn't have chosen better words myself.WoW Ralph, really looks like its starting to come together now - you got some ballz on ya fellaAll them pipes, cables, timber, venting would frighten the life outta me
Doing a fantastic job chap - keep up the good work its looking bloody brill
Thank you Ralph, for taking the time out of the busy schedule.....................to keep us allThanks again for looking![]()
Looking brilliant Ralph & BevGreat pics
cannot wait to see it at Whitby
I can nick some ideas then
Don't worry you won't be the only one on temp bedsI am hoping to pick my relay up today or tomorrow-just waiting for the call
then get some insulation in and I have a rock and roll bed (going into the vito )I can throw into it.
If you need a couple of 6ft ish x 2 ft ish new foams to borrow give me a callI have some in pool room that will eventually end up in mine
terry
I have been following this thread with total fascination and have come to the conclusion that Ralph is a lying rogue.
It is totally obvious that he is a professional cabinetmaker and part-time professional electrician, part-time professional plumber with a touch of vehicle mechanic, designer and genius thrown in.
I am also absolutely convinced that he's not human. He is from the planet Zog and has come here to make us all feel one whole lot inferior.
But seriously, you should be doing this whole conversion thing professionally.
Thank you for making me sick with envy. So looking forward to seeing the final pics in due course.
No probs Ralphyou are welcome
Guess what I got tonight
terry
No probs Mike he can come here and do this bus it's getting on my wotsitswatch out Terry he is after your work. you both do really great work.
Perhaps I'm being too simplistic, but wouldn't it make life a bit easier if you actually levelled the van first so that you had a perfectly level floor, then a spirit level COULD be used ... just a thought!You are right about no level Ralph everything has to come off the only flat thing the floor. As you have found out every bit has to be scribed to the walls and roof etc It's a steep learning curve and you are coping brilliant with it take a bit pat on the back
BTW my Relay came tonight
Terry
What happens when you get in and out of the van ? EASY to use the floor as a flat surface and 3,4,5, everything off that -once you get one bit squared both ways you can use that for accurate measuringPerhaps I'm being too simplistic, but wouldn't it make life a bit easier if you actually levelled the van first so that you had a perfectly level floor, then a spirit level COULD be used ... just a thought!
I suppose it depends how much of an 'elephant' you are ... some of us aren't quite so heavy as others!What happens when you get in and out of the van ? EASY to use the floor as a flat surface and 3,4,5, everything off that -once you get one bit squared both ways you can use that for accurate measuring-If all else fails so long as it looks right it is
terry
Nice one minxy. I'm impressedI suppose it depends how much of an 'elephant' you are ... some of us aren't quite so heavy as others!
I actually converted an ex-ambulance so totally understand the problem - getting the first 'square' sections is key and worth spending the time to get it right. This was the first time I'd ever done anything like this so it wasn't as 'sophisticated' as both your offerings, but we loved it!
