To get the latest Venus OS onto my Raspberry PI can it be done directly to the PI or do I need to do it to the SD card and re-boot from there?
Yes it has, I looked at the menu and saw firmware but didn't go any further ( what am I like) anyway all sorted now, thanks for the very quick response.Does your Ras Pi already have a previous copy of Venus OS on it?
If yes then go to the "Firmware" menu in the settings and check for the latest available firmware version and update from there.
Yes, I must play with gui mods - I am on 3.14Add has DC in settings and gui mods simple, it will show a nice overview of the flow.
Been playing with the Venus OS on a Raspberry pi for some time now and I thought "why not a screen?"
Trouble is my prefered location limited me to a 5" screen, so I purchased an Elecrow from Amazon
Together with two 5m cables - HDMI and USB at a total on less than £60, I'm quite pleased with the result.
Need to get some Matt Black acrylic sheet to finnish off...
Did I say finish? I own a campervan, I'm never finished!
I did a lot of research on this 5" screen on YouTube and they all mentioned two micro USB ports on the back of the Monitor. One was for the touchscreen feedback and one for the monitor power.You are showing the low voltage yellow arrow on both of your photos, if you are powering your screen from your Pi then that will be the reason why.
If you are powering your screen from your Pi then you would be better off powering your screen from a separate power source.
I came across this video on YouTube. Has to be the easiest install I have seen for the latest version of Venus OS onto a Raspberry Pi 4 plus how to add GUI Mods, etc. packages.
Victron VenusOS | Easiest Install possible | Raspberry Pi 4B | NO Cerbo GX or Venus GX:
You have solar water heating on the van?? Didn't even think that was an thingJust been testing on one of my spare RasPi's, temperature sensors so I can monitor our hot water tanks via my Victron screen on our van.
I'm using the cheap 1-wire DS18B20 sensors.
You have solar water heating on the van?? Didn't even think that was an thing,WOW!
Think I'd rather use the limited roof space I have for battery charging type solar.
Found enough space to fit a 5" screen and, as it's current draw is so low, I can leave it on all the time. Saves getting the phone out.Do I really need a touch screen in the van? Strikes me that the information is available on my phone, what does the screen bring to the party (other than another toy to play with, which is a valid enough reason)? Not criticising, genuine question.
If you go to settings-display, you should be able to dim the screen after a preset time.Found enough space to fit a 5" screen and, as it's current draw is so low, I can leave it on all the time. Saves getting the phone out.
That option is not available to me, presumably because I am powering the screen from a USB port. I had to 'break into' the usb lead so as to insert the push switch on the right.If you go to settings-display, you should be able to dim the screen after a preset time.
I dim after 1minute.
How are you powering your screen?As Raul says you should have the option to dim and turn off your screen.
In the "Device List" screen, tap on "Settings" and scroll down to "Display & language" and within that menu you will have these options.
When I last looked a coupe of weeks ago the Pi 5 isn't supported on Venus yet. Lucky I checked as I was just hovering on the "buy it now" button. Apparently a BT dongle improves the range of the older ones, but not tried myself yet.I've been playing with a 3B, now the 4B is available again at a sensible price and even the 5 is not extortionate, is there much advantage in upgrading?
When I eventually mount it in a van it will be hard wired. The Bluetooth & WiFi range on the 3B is so poor it's unusable are the 4 & 5 any better?
