how easy is it to upgrade ram on an asus laptop,is it something I could do myself(is it just a case of plugging a bit in) or should I get someone to do it, it has 4gb but think i need more for video editing
its an asus vivobook 17 4gb ram 1tb hardrive model x705mIt's easy, but two things to note on the laptop.
1. Research the model number online - many different ways to take the machine apart to access the DRAM slots. Some machines have a simple hatch with a couple of screws, or might even be toolless. Others need a fairly major disassembly (screws and clips).
2. Make sure you remove the battery – this is even more important on machines where the battery is not externally removable. In these cases you might have to disconnect the battery lead that goes into the motherboard once the back is off.
But, all models are different.
Want to share the model #?
