What type of boiler do you have. Is there water leaking underneath?Hi don't have one just the manual yellow lever and that's closed ..
Truma ...no water leaking anywhereWhat type of boiler do you have. Is there water leaking underneath?
How high is your water tank level compared to the pump?. If there's no water if you take the fliter off is there either a blockage or air trap in the feed pipe I'm pretty sure that the filter is between the pump and water tank so would expect some water to come out when you take the bowl off.There doesn't seem to be water at the filter just removed it with it running ...? is there a way to test the pump to see if its pulling water from the tank is there a diaphragm in side it or something to check ,,?
ok thanks i will get under and have a look ,, just looked nothing leaking pipe looks good ,,there seems to be water at the bowl now but its not pushing it through to the boiler ,,might get a new pump ,,be handy to have a spare,. even if its not the pump .dont know what else to try ,,If there is no water going into filter housing it may well be split, and the pump is sucking in air. Air won’t pressurise the system, so pump will never turn off.
thanks no external shower ,,Hi
I had trouble with my pump continuously running,I found the the fault to be the outside shower attachment , it had excessive water build up in the little external shower cover ,
Water was touch the little pump switch, This was on burstner ixeo . It happened a couple of times now , but just released water and dry switch and pump stops running shorted. And works how it should.
Not sure if applicable to your van,
Ref external shower .
Cheers...I get a new pump £50 from halfords...Ok was a long shot, but I hope you mange to get it sorted soon, as I know how frustrating it can be just not knowing the actual fault .
Any way good luck rob.
Not sure a pressure pump has gears unlike a submersible pump.If you have a tank full of water but none to any tap, can I suggest that the pumps gears has sheered/stripped?
this it https://www.halfords.com/camping/wa...AC7YzY-ZX5pjdvO9JCH8QUQ5aAdsUd8hoC1VMQAvD_BwESame make? mine says pentair shurflo ,,halford just says shurflo ?
Same pressure? yes 20psi
Same flow rate? yes mine is 7 lpm ,,this i i.2 gallon per min think its about the same ?
hi thanks how can i test this ,,i have stripped it down cant see any debris or any thing in it ,,If you have a tank full of water but none to any tap, can I suggest that the pumps gears has sheered/stripped?
It has a wobble disc driven off the motor shaft which pushes each diaphragm in turn
i think i agree when i striped it down the shaft looks as though it off center when i turns i though is that correct ,,but you saying wobble disk ,,might be correct ,,Not sure a pressure pump has gears unlike a submersible pump.
Thanks was thinking about that need to set something up to try it ..Have you stripped it and examined the diaphragm as shown in the video and while you have it stripped, connect it up for a few seconds and see if all is operating correctly.
If all appears ok, rebuild then disconnected the outlet pipe of the pump, put the end of the pipe into a container of water to see if that helps without the pressure to the system?
I picked mine up from a supplier on EBay. Just happened to be in Bolton where I live, he had all the different models on the selves.thanks for all the info ,,can anyone suggest where to get an exact replacement this is the number on mine 4029-181-A32 halfords do one similar but not the same number not sure if you can change or not ,,?
