Saltings
Protimeter Aqua 2 (1 Viewer)
Saltings
228
33
Buckinghamshire, U.K.
Chasson C626 Flash
since 2115
Saltings submitted a new resource:
Protimeter Aqua 2 - Views on this moisture meter
Does anyone have any experience with this rather expensive moisture meter? Having experienced a agent using an invasive moisture meter and then charging the earth thought we would do our own Hab. Checks next year.
Saltings
Chausson C626 Flash (2014)
Read more about this resource...
Snowytoot
having used the protimeter rang extensively over the past 20 years and ended up with the Aquant about 5 years ago I can vouch for their reliability and accuracy.
We have found though that although very good they take practice and a back up probe to really trace any ingress once found.
if serious about doing your own habitation checks the right equipment required to do it correctly is expensive and would take about 7 years to pay for itself at £175 a year.
if buying now I would recommend the one in the below link as although very expensive it will do all that is required.
https://www.tester.co.uk/bdl5365-protimeter-surveymaster-moisture-meter
Saltings
Saltings
228
33
Chasson C626 Flash
since 2115
Cheers Snowy,
Will take a look at the link, have also had the Aquant recommended. Apparently Protimeter say that virtually all motor home dealers use that model.
Saltings
