Protecting mattress between spars and garage (1 Viewer)
Apr 22, 2023
27
24
Scotland, UK
GR73tLX:fzBDbY!
Burstner I'm new
Apologies, I have asked this before and simply can't remember the help I was given - What can I put under the spars of the bed to protect the mattress from items in the garage. I know it should need air to circulate.
Jun 6, 2019
89
63
Since 2019
Have you checked your old posts to see what responses you got last time? I personally dont use anything and everything seems fine.
btw, the Moho model in your profile looks very strange. Hope it isn't your password :giggle:
3,687
10,269
1995-2004 & 2017》
Well, after asking and being advised you obviously did not act.... so issue could not have been that critical..
Tombola
4,847
15,759
Merseyside
Rapido 8094DF
Puts anything you like.
The spars will allow enough circulation
19,417
30,533
Well if you have asked before I can't find it on a search so let's start again :unsure: not sure what sort of things you have in the garage that are likely to cause problems but would some of that weed suppressing membrane that you get in garden centres do the job? it lets water through so will obviously breath as well.
4,002
6,266
Rochester
Auto-Trail Mohawk
16 fun filled years
K
Apr 22, 2023
27
24
Scotland, UK
GR73tLX:fzBDbY!
Burstner I'm new
I did ask before and I couldn't find it either, hence the reason for asking again. I want to protect the mattress from items which may get wet or dirty and I have to pack them away before I can get dried/cleaned off.
K
Apr 22, 2023
27
24
Scotland, UK
GR73tLX:fzBDbY!
Burstner I'm new
Really?? I never said it was critical. There are reasons why people don't 'act' and require help again.
K
Apr 22, 2023
27
24
Scotland, UK
GR73tLX:fzBDbY!
Burstner I'm new
My Autotrail came with plastic mesh sheet fitted under the fixed bed mattress over the garage. The link below would do the the same I would have thought.
https://www.rubbersmart.co.uk/product/dri-vent-anti-moisture-mattress-underlay/
Found it, this is what I have, not sure if it's standard Auto-trial or if the previous owner fitted it.
https://shipshapebedding.co.uk/shop/dry-mat
Thanks for that really helpful answer. I need to protect the mattress from things which may get wet or dirty and I have to pack them away quickly before I can get dried/cleaned off.
Tombola
4,847
15,759
Merseyside
Rapido 8094DF
Wouldn't worry too much OP anything will do whether that be board to protect prods and pokes (pardon) or poly to protect smell or damp etc...whatever works the mattress will breath
K
Apr 22, 2023
27
24
Scotland, UK
GR73tLX:fzBDbY!
Burstner I'm new
K
Apr 22, 2023
27
24
Scotland, UK
GR73tLX:fzBDbY!
Burstner I'm new
Thanks for that.
19,417
30,533
So the membrane stuff I mentioned above or some plastic netting but put it under the slats and staple on rather than above the slats and against the mattress.
2,380
10,353
Our 2001 Hymer B644 garage roof was boarded out ..
It was like that when purchased and I assume it was done by Hymer.. not a DIY job
