Problem with mains charging or battery, can anyone help please?
Early days as I said:D
is this what you mean?
https://www.tayna.co.uk/battery-chargers/ctek/d250sa/?
gclid=EAIaIQobChMI_MSqpued4wIVCJ7VCh3A9wFKEAQYASABEgL9BfD_BwE
(not sure I've sussed links on the new format!)
That is cheaper than what I was expecting if the EBL needed to be replaced though.
No mate.. that is dc to dc. You are looking for an ac to dc charger
Looks like CTEK have dropped their version for some reason..
Both of these look reasonable spec though, and not OTT money wise
Cheers John. All I did was Google ctek 20amp charger :D wouldn't have bought without triple checking!
If you have a schaudt ekectroblock, you can get a schaudt charger.
They are 18 amp and they recon for every 10 amp leisure battery you have 1 amp charger.
Hence I have 360 amps leisure batteries and had a second schaudt charger fitted as they are 18 amps each.
When the solar panels were fitted, if the schaudt solar regulator was fitted, the dt201 panel displays the solar input.
Don't know if this is any use.
Most of the instructions are available in English online.
What mh do you have?
Thanks Sue.
Van bitz fitted the solar set up & additional battery
2 of these
http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=321391676110
As space is so limited I opted for 2 more of these as replacements this week.
The solar set up isnt connected to the EBL/schaudt panel.
I've got an Adria Vision on a Renault Master
Was it the vehicle alarm? I had this on my last van (swift sundance), the alarm uses the starter battery, which doesn't charge on hook up. When the starter battery drops to a certain level, the alarm goes off. Easily cured by taking the van for a run every week.
