Found the extent of the damp inside. Bad, but not disastrous.I will now bond in a whole 3mm plywood panel to this area before the stainless reinforcements.As it sounds like you know what you are doing, I would repair the torn fibreglass and bond on a sheet of stainless to take the structural weight, as well as oversized stainless plates inside. Then bond the fibreglass frame back in with a few tubes of Sikaflex rather than mastic. That should keep it watertight and stronger than when it left the factory
Thanksn but P40 is only a filler, I need a 2 part resin to soak into the woven mat and then adhere to the van side wall.Isopon P40 is fibre reinforced filler , it dries very solid
Fantastic, thanks very much, have now emailed themFor the internal wallboard, try O'Learys as they stock a lot of Autotrail stuff for the older models.
The West System works very well and doesn't dissolve the insulation like some polyester resins do.Thanksn but P40 is only a filler, I need a 2 part resin to soak into the woven mat and then adhere to the van side wall.
Funnily enough that is what is in the Bodging cupboard.The West System works very well and doesn't dissolve the insulation like some polyester resins do.
You are doing a grand job.
My mistake was not looking closely to this area when we bought it a couple of months ago. Luckily I have a Masters in Mystical Bodgerama and a garage full of things that might come in useful one day. God knows how much this would cost to get fixed if taken to a repair shop.Think I need to remove the covers and check the state of play with mine, seeing that it’s also a 2006 and pretty much identical to yours.
Seriously big well done to you and the misses dot the work so far, you’re doing a great job![]()
Thinking that now it is a whole cupboard we could do it in sticky back carpet or similarLooking at your repair (which looks really good, I must say) as it's a small area, if you can't get any matching wallboard, maybe you could use a 'speckled' paint spray rattle can to get a close match to the existing wallboard.
I was just about to suggest the same?Will you be looking at and strengthening the other fixing the other end..?
Yes as I said earlier in thread ,I reckon the mastic used is what has been holding it on & has only just started to let go. If you imagine that assembly without the mastic the whole lot would have parted company with the body within a few miles. very poor design.o be honest, the current mastic used has been very effective, but the top face application was not as good s the bottom face, which stuck like sh1t to the blanket.
It’s on the top of my list of things to do when I’m next at the storage yard, it’ll be interesting to see how mine is after 16 years or soWill you be looking at and strengthening the other fixing the other end..?
I bet all autotrail owners now looking in their cupboards a bit closer now…![]()
Just been and checked both mountings and thank goodness they’re fine, no signs of water ingress, cracking or failures.It’s on the top of my list of things to do when I’m next at the storage yard, it’ll be interesting to see how mine is after 16 years or so![]()
One of the washers looks to be newer than the rest and I can see some slight rust marks . I am sure it’s absolutely fine but I would still use a damp meter in that area just to be 100% sure .Just been and checked both mountings and thank goodness they’re fine, no signs of water ingress, cracking or failures.
I can sleep again now
Front:
Rear:
Both wallboard and the covering available here.Found the extent of the damp inside. Bad, but not disastrous.I will now bond in a whole 3mm plywood panel to this area before the stainless reinforcements.
Dont like using Sika 291 - it is just too damned good, and would never be able to break out the moulding again without serious damage. To be honest, the current mastic used has been very effective, but the top face application was not as good s the bottom face, which stuck like sh1t to the blanket.
Anyone know where I can get some of the decorative inside covering?
it is https://www.thecaravanwarehouse.co.uk/Both wallboard and the covering available here.
Search their site for Kenkle wallboard & Kenkle wall paper.
I can't get the link to work, just Google caravan warehouse Swansea and search their site for Kenkle.
Front top has been replaced, you can see the mastic around the base of the washer.One of the washers looks to be newer than the rest and I can see some slight rust marks . I am sure it’s absolutely fine but I would still use a damp meter in that area just to be 100% sure .
I’ve also just noticed one of the retaining screws is rusty . Get that damp meter out PP Bear .Front top has been replaced, you can see the mastic around the base of the washer.
Please also bear in mind, minbe was not obvious from casual glance. I you carefully remove all 3 nuts you can get a reading from underneath the big bracket. 2 minute job, 2 years of relief.
Always thought that you had a screw loose, and there is the proof for all to seeJust been and checked both mountings and thank goodness they’re fine, no signs of water ingress, cracking or failures.
Front:
Rear:
Brit made van like mine . Cost cutting wherever they can . Some of the wiring in my swift is well underrated for the job . It’s all about saving pennies wherever they can .Why would they not have used stainless steel screws?
In theory at least this is not a corrosion area, as it is supposed to be dry. Also, note that those nuts and bolts are not corroded through after 16 years, just surface rust. Now consider the cost of using all stainless fixings, and you have a profitability issue when you add up the cost of a model run over 10 years. Every little helps.Why would they not have used stainless steel screws?
