Precautions when plugging in to mains electricity (1 Viewer)
popotla
153
103
Germany
3.5t on Ford Ranger
Come to Germany! It's great for motorhoming/van life.
I feel a bit dumb about this but here goes ................
For many years we (wife and I) travelled in our Land Rover Defender but now have our first motorhome. We have never used electrical plug-in for on-site electricity and although we have one of these
https://kalledaskabel.de/CEE-Verlaengerung-KALLE-Blue-SIGNAL-25mm-Winkel-25-Meter
don't know something key - super-important, I believe - about plugging it in. It's necessary, isn't it, in order to protect the vehicle electrical system, to first switch something in the vehicle OFF before plugging into the mains?
What are the precautions to be aware of? We expect to be using sites in Germany, the Netherlands, the UK, Scandinavia.
DBK
18,025
48,095
Plympton, Devon
PVC, Murvi Morocco
I would always turn off the heating if we had it on the electric setting before uncoupling the EHU. Ditto the fridge. This would prevent any arcing at the pins which over time will degrade them. But otherwise I wouldn't bother on the initial connection. The mains charger will connect automatically whatever you do, or at least it does on ours.
The only thing I can think of you might be referring to is the vehicle mounted RCD but I would never turn that off before connecting the EHU and I've never seen this recommended. :)
RogerThat
1,128
991
North West
PVC
I've never switched power off on any of my vans.
My only safety tip would be to plug the van end in first, then connect the mains end to the bollard.
I often see people connecting to the bollard first, then unwinding the now-live mains cable out towards their van, by hand.
If that cable has a nick in it from their last trip, it may have got snagged on a fence, a field mouse may have taken a fancy to it, anything really - but they may find out their cable is damaged the hard way.... :(
23,785
133,703
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
But it does give them an instant health & heart strength check for free(y)
1,044
999
Cumbria
Pilote P740FC
The Caravan & Motorhome Club do produce an advice leaflet -https://www.caravanclub.co.uk/uk-holidays/useful-information/hooking-up-to-the-mains/ - which appears to advise this. But to be honest it feels like overkill and we’ve never done it.
Jaws
23,836
72,487
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
To some extent it depends on the motorhome you have.
We have an Autotrail with a Sargent system fitted.
In the owners manual it does say the Sargent unit must be switched off before using hook up.By switching it off, it turns the whole 240v system off, so no worries about checking the heating etc.
Knowing how flaky the Sargent box's can be I have always followed the instructions
Other vans will have a different procedure, but basically try to make sure things are off before plugging in
TheBig1
17,630
43,280
ALWAYS check your lead before use. Plug into the van first and always fully unwind the cable. Then plug into the bollard and remember some bollards require you put the plug in and turn it to switch on the electricity
43,330
49,446
And beware of reversed polarity.... Live and neutral wired the wrong way round.
Harmless, but always runs to page after page of pointless forum posts to keep the masses entertained.
Almost as entertaining and pointless as Gassing threads
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
You are right to be cautious, especially with mains electricity. Heed the advice given above, but it may not be that critical. There will be many who are ignorant of such advice but there seems to be little evidence of there being many accidents as a result.
popotla
popotla
153
103
Germany
3.5t on Ford Ranger
(Jaws) To some extent it depends on the motorhome you have.
Our motorhome is a Burow Oman, as shown in the photo below. It's a new vehicle but there is no owners' handbook. I don't know why.
We have an 80 Ah AGM starter batter, two Lithium-Ion 100 Ah on-board batteries and 2 x 110 W solar. These are linked together via a Votronic Power Control unit.
The Caravan and Motorhome Club guidelines recommend that the Isolating Switch is at "OFF"; it was this that I was getting at in my original post. "Isolating Switch"? I don't know that there is one in the Oman. In our Land Rover there were two isolating switches in the circuitry, manual ones (twist one way or twist the other).
(pappajohn) beware of reversed polarity.... Live and neutral wired the wrong way round ...... [but it's] harmless.
According to https://caravanchronicles.com/guides/understanding-reverse-polarity/
...... 99% of the time, this (RP) is not a problem…. until that is, someone decides to put their fingers into the toaster for what ever reason…. they can touch a live element. So the toaster doesn’t even need to have a fault with it. It can still be potentially dangerous.
The same site also says (their emphasis):
If it (a socket tester) indicates anything that is not “normal”, switch off your van’s master switch and unplug from the bollard.
1,251
2,369
Wellington, Telford, Shropshire
Van Conversion
Since 1977
I always consider it as important if not more so to check the full length of the cable for damage when I disconnect it. To do this I always run the cable through a wipe in the middle of my hand thus detecting any cuts, snags etc. and have it clean for stowing.
I'm reminded of the morning that I found a squirrel 'nibble' in a cable, not easily noticeable but potentially dangerous!
As for isolating the interior, I never do but there again I only have very simple consumers on board.
4,762
24,961
B&NES
Van Conversion
since 2007
If your MH is an import that still has 230v 2 pin continental sockets inside, my lazy solution for reverse polarity was to turn the 2 pin to UK 3 pin adapter upside down so that the UK 230v polarity became the right way round. Having said that, there might still be a risk due to a missing earth connection but I'm not sure.
I also made up a short length of EHU cable with a reverse wired blue socket that could be inserted between the long EHU cable and the bollard, to correct reverse polarity. That DIY fix was based on an article in a MH magazine a while back.
6,873
7,993
Manchester
A class Hymer
Since the 80s
No need to take any precautions, just plug in. I always plug into the EHU post first, then unwind the cable so that the excess is under the MH. Not recommended according to some, but I can't see the problem.
There is an RCD in the EHU post that will trip to prevent electric shock in the very unlikely event of a problem. For nearly all problems it will trip as soon as you plug it in.
On some of the aires and more remote camp sites in southern Europe I wouldn't be quite so cavalier, having seen their more creative approach to electrical installation. Especially if it's raining and everything is wet. Best to plug in the MH end first, then plug in the EHU post.
If you have a fan heater, make sure that's off, or turned in a safe direction, as it could have moved while travelling. And make sure it has an automatic cutoff if it falls over. Other than that, I don't bother switching anything off.
6,823
12,579
Herts.
Adria Coral lowline
I make sure my boiler is off when I plug in, or unplug, and when unplugging, I turn the boiler off and give it a few minutes to settle before pulling the plug out of the van.
The point of connecting to the van then going to ehu point is that you at not handling a live cable, that could potentially be damaged.
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
Yep, just plug it in - van first then bollard
The amount of seasoned caravanners and motorhomers that totally disregard this is amazing. I was on a site at Devizes recently and every caravan that pulled in on my side plugged onto the mains first and also 2motorhomes opposite me did the same And these were not newbies
6,873
7,993
Manchester
A class Hymer
Since the 80s
If it's wired to comply with the regulations, there will be a Residual Current Device (RCD) controlling all the mains input, near where it comes into the MH. An RCD is an automatic trip switch with a 'test button', and you're supposed to test it every few months to check it's still working. Therefore it should have been positioned where you can access it easily. You need to find this switch, because if it trips unexpectedly as they occasionally do, you will need to know how to reset it.
6,873
7,993
Manchester
A class Hymer
Since the 80s
Those with nice modern motorhomes wired by knowledgeable manufacturers can afford to ridicule concerns about older British motorhomes on Continental trips.
Reverse polarity would be a problem in a British house, because circuit breakers (MCBs) are on the live conductor, many socket switches turn off only the live conductor, and anyway all appliances have a fuse in the live conductor. Reversing the polarity means that a fault that trips the circuit breaker or blows a fuse still leaves one of the wires connected. That wire is normally the neutral, which is safe to touch, but in the reverse polarity scenario is becomes the live wire. British electricians take great care to connect houses and campsite EHU posts with the correct polarity.
In contrast, in a European house, all the circuit breakers and switches are double-pole, and no appliances are fused. When the circuit breaker trips, both wires are isolated. Reverse polarity is not a problem, so they are less careful about wiring with correct polarity. German/Spanish domestic plugs are reversible, so it's 50/50 which polarity you get even with a correctly wired socket.
The problem comes when a British motorhome, wired like a British house, is plugged into a European socket. It's quite likely to be wired with reverse polarity.
If the motorhome has an RCD, that will protect against shock even when polarity is reversed. Any MH from 2008 will have an RCD, and double pole circuit breakers as well. Many earlier ones also have them. Before 2008 it's worth checking - some have RCDs, many don't. Some DIY conversions by converters not conversant with the regs may fit single-pole MCBs. But anyway, the fact that appliances have a fuse in the plug means they are susceptible to hazard due to reverse polarity.
So in summary, if you have an older British MH or a DIY conversion, its worth checking to see if there's an RCD fitted. If not, get one fitted, it's usually quite easy. It's easier than buying a tester and reverse polarity adapter, and using it every time you plug in.
How to tell if you have an RCD? It's the one with a 'test button'. MCBs don't have a test button.
There is a device called an RCBO, which combines the function of an RCD and MCB. It also has a test button. Last time I looked, they were more expensive than a separate RCD and MCB. But they are useful, especially in a motorhome, where often there is only one MCB. In a house there's usually one or two RCDs and a dozen or more MCBs.
43,330
49,446
You're referring to lack of a suitable earth, or the fools at caravanchronicals are.
A heating element (toaster etc) has a live wire connected to one end of an element and a neutral wire connected to the other.
It makes no difference which end either wire is connected to the element is still live and will still give you a shock at least.
Reverse polarity is only swapping the live and neutral at source and the element will be live regardless.
43,330
49,446
See what I mean...... This may run to dozens of posts now. :LOL:
6,873
7,993
Manchester
A class Hymer
Since the 80s
I could start off a similar argument by suggesting seat belts are a waste of time, or you could increase your payload by ditching your fire extinguisher. Some responsible person would feel compelled to reply in case flippant comments were taken on board and acted upon by newbies. Congratulations, @pappajohn
thebriars
1,149
2,182
Teesside
Since 1990
I bet if you checked a dozen British houses you would find at least one reversed polarity socket which has been in use constantly and nobody has ever been the wiser, or electrocuted. Frankly it doesn't matter where a fuse is in a circuit, it will work just the same.
6,873
7,993
Manchester
A class Hymer
Since the 80s
If you checked a dozen British motorhomes you'd probably find no-one that's ever used a fire extinguisher in anger or had their life saved by a seatbelt.
Reverse polarity is a safety issue, not a functionality issue. Like when the wire gets trapped in the metal frame of a folding table which cuts through the insulation. The wire contacts the metal frame, the fuse blows, and if the polarity is reversed the metal frame stays live.
If there's an RCD somewhere - in the EHU post or the motorhome - it will trip. Otherwise it stays live.
364
919
Burrough on the Hill, Leicestershire
Rapido 886f
Since 2014
Reversed polarity will leave the supply to an appliance live when you operate the switch. Only an issue for UK devices as we use single pole switches whereas Europeans use double pole switches i.e we only switch (break) the live wire, Europeans switch both the live and neutral wires. Unlikely to kill you but you might require fresh underpants.
Back to the OP - I like the plug on that cable. Very useful cable lies flat against the van and you get a useable outdoor socket.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
I always stand on only one leg when connecting up,
It works for me.
Never known anyone being electrocuted like that!
