Yes, I've seen lots of pictures on the net , I'm getting excited, I may be able to have my roof mounted solar panel
Ouch......I have had a quote for 800 pounds to supply and fit a flexible 160w solar panel,
That would depend on how much you use the battery and how long the alternator was allowed to run to help out.I do not understand this solar stuff. To trickle charge a car battery (assume largest) what size portable panel producing whatever you measure would suffice to keep the battery charged????
if you were to continually crank the engine even a large panel would struggle to cope with charging...especially in the uk.
if you mean to just keep your starter battery topped up on the drive....there are 10w panels available, which people often use on cars that don’t get much use.
I’m guessing there won’t be much sun in the garage.....Assume i am leaving the car locked up in the garage for 4/6 months. Not using at all. So want/need the battery to be trickle charged.............
Haha, yes it would go on the garage roof..........the panel not the carI’m guessing there won’t be much sun in the garage.....
But a small 10-20w panel outside or on the garage roof should suffice.
I’m sure a 2kw ‘alternative’ brand diesel heater will be fine.....if you can find a willing installer.I have no garage and have to park on the public road , so that's why I fancy a roof panel, I am thinking of going out more in the winter, although I need a heater installed for that
Strewth, that's expensive!!!! I've never ever heard of a 'perforated' panelI have had a quote for 800 pounds to supply and fit a flexible 160w solar panel, I asked about overheating and he said it was a perforated panel . He seemed very confident and the customer reviews were very good. The company is called Falcon Technology, the price did seem quite high, but it's important to me to have a good quality installation and the right solar panel.
Weird....I hope it’s not contagiousI don't understand its underlined lol
I know you need to manually push your roof up but you could do a 'test' to see if you can manage to do it with the weight of a rigid panel on ... try taping some weight to the roof to match that of the panel where you want the panel to go and try lifting it ... if you can and it stays in place then you can go for a rigid one instead.That's why I'm doing my homework, there seems to be pros and cons to everything .
Stick with it....you’ll get exactly what you want eventually.Good idea, I'm assuming that to hey would place it near the front of my van where the lift is less .
The more I look into it, the more my brain turns to mush![]()
