No Battery master fittedAn Anderson socket off the hab battery is useful as a speedy plug in for a solar panel.If used with a decent sized cable off the battery it can also be used as a supply for an inverter.
Have you fitted a battery master ?
Mike.
No Battery master fitted,removed battery today and took these 2 pics of fuses connected to positive terminal.First fuse 50 amp looks fine . 2nd one on a thinner wire 20 amp fuse with some burning to the fuse holder.Battery wasn’t turning engine over took it to a friends measuring 10.2 on his meter . New battery ordered bit concerned about burning on the fuse holder on second red wire .
