Camdoon
Usual thing that the water pump was pulsing every few minutes and found water in the shower when it had not been in use. Managed to check and it is not the tap but the pipe joint. The issue then is access to that area. There is an access cover to the joints but the joints are both above and below the access point. While I could loosen the tap I do not think it possible to loosen the joints using fingers given the tight access and risk of pulling something further along the pipework. My man who does for me has not been asked but is busy to June even if he could. When tested some of the water flows into the shower area at the bottom and the rest appears to run out the van.
Not sure where to start as there is no way I can see that it could be done without either cutting a bigger access hole or taking the shower to bits both of which are not appealing.
The other option is does anyone know anyone in Cambs or within an hour or so who might fix this properly.
While difficult to photograph the second last image shows the joints peeping out when photographed from below; the last taken by putting my phone in the gap.
Any help gratefully received.
