Peugeot Boxer engine warning light - Help!
Let me know if your electric steering fails. I fixed the wife's 207 recently and after horror tales on the web I was pleased I did it for £230
Thanks Techno, not heard of that problem before. My car is the 1.4, I have heard many bad things about the 1.6HDI version
Yes wife's is 1.4 petrol 2010 but most have same motor. Seller will confirm which with reg number
It failed right out of the blue as she arrived at work and couldn't turn it into a parking space
Hello, Thank you for the add. I Hope RichardB could tell me how he resolved the code P0603. I have the dreaded Kam Fail code on my Citroen relay coming on , keep clearing it and looking for the fault? Any thoughts?
Thank you
Andrew
Thank you
Andrew
Hi Andrew, have you had the ecu firmware updated with the recall? jf not you need to
Hello Thank you for the reply. Who can do that? Did it happen to you? Ive owned it 3 years previous no real issues
Hi Andrew the recall should be done by a citroen garage
Most engine-related problems that show the 'engine' light and that don't force limp mode are focussed on emissions systems hence my comment. Even limp mode is there more to force a dealer visit than to prevent engine damage.
When I had that error I think it was because it was sat for some time so I reset them and took the van for a long drive up the motorway and give it a good run at 70mph in various gears.
I had cruise control fitted to my current van, and after that the engine light lit and was showing a number of problems including P0603 again - the guy who fitted the CC said that this happens sometimes as it screws the ECU while fitting so again, just reset them all and drove 150 miles home on motorway and they haven't been on since!
(That said I am going in out in the van tomorrow and it hasn't moved for 2 months - sods law a light will come on!)
Richard
Does it make a difference if its a 3 litre? as i have the same fault on a 3 litre engine, bought a code reader came up with no faults, changed water temp sensor still on. van runs ok, got a little hunting when stood, any ideas
Your replying to a six year old post..
