Sorry - wax motor action described back to front! Should be expanding wax on melting pushing against a return spring. This means default setting for the a cold pump is ”timing advanced”:
When the heat source is energized, the wax block is heated and it expands, driving the plunger outwards by volume displacement. When the heat source is removed, the wax block contracts as it cools and the wax solidifies. For the plunger to withdraw, a biasing force is usually required to overcome the mechanical resistance of seals that contain the liquid wax. The biasing force is typically 20% to 30% of the operating force and often provided by a mechanical spring or gravity-fed dead weight applied externally into the wax motor (Duerig 1990, p. 214).
en.wikipedia.org
