P24D1-92 DTC - Faulty Particulate Matter sensor, Fiat Ducato 2.3 140 Adria Compact
Adria Compact SC
I appreceate this is a bit of a known issue and has probably been discussed many times previously, but I've tried searching and can't find a definitive answer.
I've had this P24D1-92 DTC issue on my 2021 Fiat Ducato Adria Compact for about the last 4 months. It's been reset and it keeps coming back. When it comes on it disables start/stop and sticks you in one power mode.
Has anyone replaced this Particulate Matter sensor themselves, is it an easy job or is it best to give it to Fiat Professional dealer?
TIA
Mike
If you are referring to the dpf sensor ( exhaust particulate sensor) then it’s simply 2 small bolts a wiring clip and 2 small hose clips.
The sensor was low down a the chassis near the offside front wheel.
On later models I believe it’s mounted higher up but same side.
Hi Phil, that's great, thanks for replying I assume being a 2021 I have the latter version, is it accessible from under the bonnet or from underneath do you know?
Mike
Reactions: f6c
Phill D i think you are refering to the differential dpf pressure sensor which was a "popular" failure on the x250 .
mike_babb your problem P24D1-92 is related to the "particulate matter sensor" as used on Adblue models. its located on the DPF. was a common failure, apparently it is a superseded part now
You are correct I was referring to the DPF and I thought I made that statement in my post.
In fact I asked the op if that was what was being referred to!
I know you know what you are talking about. We had too many discussions where that damnned sensor is , I have an X290 and i couldnt find it where you were telling me it was. Problem realy is Fiat and thier poor Nomenclature, too many DPF sensors. Both are used to measure how blocked the DPF is, but in different ways.
Thanks guys. I only stated that it was a Particulate Matter sensor because that is what it displayed on the fault reader display. Are there any schematics available for this DPF sensor?
the differential-pressure-sensor is dealt with in this guide. And can be diagnosed with following info,
The particulate mater sensor is a 2 part sensor and control unit sold as one unit fitted to the 2.3 adblu model.
Some errors are in the connector.
I couldn''t find any photos of it in position, if you manage to get it done could you photograph it for me please.
That
That is super-helpful, thanks. If I find it I'll be sure to take a photo and post it.
I note from the link to the Fiat Forum that if you change the sensor it will require reprogramming to the ecu. Is that not something that a Fiat Professional garage, or similar, will have to do?
Mike
No it can be done Diy with very specific kit.
how to select what you need from Gendan (simplest method)
Thanks 👍
Sorry to resurrect this again, I'm back from a few weeks away and keen to put this to bed. I've had another look under the van and cannot find this sensor for the life of me. I have a local garage that will replace it for me if I provide them with the part. I would rather source a genuine part supplied by Fiat anyway. Fiat say that the part number is 5190 8411, but when I Google that part I come up with something that looks more like this, which doesn't look like the Bosch part in the image above. Which one is then part that has the track record of failing? I don't want to get the wrong sensor.
Has your van got Adblu?
The part shown above is the differential pressure dpf sensor
The code you quoted implicates the particulate mater sensor which is a 2 part sensor and control unit sold as one unit fitted to the 2.3 adblu model. Contact Fiat with the code and vin number for clarity.
That
Mike
A useful post, thanks
Thanks for that diagram. 👍
Just popped head under van. Is it this?
Actually, comparing the exploded diagram, I can see that it's not the cat. I think the cat is way more inaccessible!
The later Ducatos must be the easiest engine spaces to work in and the quality and ease of getting fiat information is beyond, beyond.
Hi, I have just posted regarding this issue. Did you get it sorted? Was is part 6 as stated in post #18?
Hi, just read your thread, there's a useful plan of the system on there. The van went into an indy garage and I'm awaiting a call back with regards to which sensor requires replacing. I'll update this thread when I have more information.
Be interested in seeing what you find out - I'm getting very confused on the different parts. My software gives a P24AE fault code which is apparently the 'particular matter sensor'. However, Fiat told me it as a Nox sensor fault which seems to be a different thing. The Fiat direct part 6 above calls it a anti pollution sensor. Difficult to know what part to order!!
ducato-gas-particle-nox-sensor from coastal motor homes, give them a bell and state the error code they might have come across it all ready
Am i correct in remembering coastal motorhomes give a funsters discount@ VXman
someone on a Fiat forum said that the photo there doesn't match the part number - the part number is a temperature sensor.
Before you purchase ask for the sensor related to your error code and Vin number
