suavecarve
If I were 300kgs over I would think about it carefully then ask the 4 illegals if they wouldnt mind awfully disembarking.
Yes, in an Anglian Water work van when the weighbridge was at Risby on the A14. Never in a MH.has anyone actually been stopped in the UK and had the van weighed? Just asking .....
Yup.has anyone actually been stopped in the UK and had the van weighed? Just asking .....
Those illegals tend to be pretty skinny. You've probably missed a coupleIf I were 300kgs over I would think about it carefully then ask the 4 illegals if they wouldnt mind awfully disembarking.
You could do what my mate did.Rang a local cab firm loaded it all in that .No prize will be awarded for saying "the spouse". Semi-serious question, if you were stuck in a lay-by 100mls from home how would you lose a couple of hundred kilos?
Off topic but I see the wife-carriers are due to be the first using the new Digital vaccination certificates from the EUI had my MH weighed the other day and was very surprised to find I was 3513KG (need to be under 3500KG). So to be fully-serious, if you or me had an accident and some one was injured or god help us killed and we were overweight we have a life changing situation. If you kill someone doing 40mph in a 30 limit its an issue, so is being overweight. Now I don't want to take the Fun out of MHF but I think we need to make sure we are within weight or up plate.
So just to lighten up this post, I took out two excess leisure batteries, removed the awning, took out 24 litres of bottled water, removed my apocalyptic survival things, like two jacks, and lost about 250 or 300Kg.
Just my opinion you understand.
the plate is only that +/- if a multiplate.if a single plate it is 50kgs.And what about weighbridge tolerances +/- 110kg on a plate, +/- 150kg per axle on a Dynamic.
Be safe travel 300 kg under like we do.
Over 5 miles you can claim all your expenses.said follow us to a weighbridge, which was miles after the exit we should have taken.
Shhhh !Those illegals tend to be pretty skinny. You've probably missed a couple
