popotla
- Jun 5, 2018
- 153
- 106
- 3.5t on Ford Ranger
- Come to Germany! It's great for motorhoming/van life.
I am trying to get to the bottom of our van's "weight problem", if indeed there is one, and would like to ask for your advice and comments on this.
The permitted total loading is 3,500kg ("empty weight", 28259, with front axle loading @ 1480, rear at 2,150. I assume this means (am I right?) that the front ale loading could be, for example, 1480, but in this case the rear loading could be only 2020. Similarly, the weight on the rear could be up to 2150 kg, but then the front could be not more than 1,350. [In all cases, a total of 3,500 is allowed.]
Recently I had the van weighed (total weight only; indiv. axle loadings not possible). There was 90 liters of water on board, a three-quarter full fuel tank, and me (no passenger): "3,460 kg", I was told.
The following day I had the axles weighed (to determine total weight at that place was not possible). The resuts were: front, 1,250; rear, 2,000, totalling 3,250 kg. Quite a discrepancy here, one of 210kg, as I understand it.
I would be glad to be further enlightened about this, and to be told whether there may be something here I'm failing to understand. [And if the first weight (3,460kg) was correct, then with two of us in the van and full tanks, we'd be overweight.]
