Open and Shut door issue (1 Viewer)
Apr 24, 2023
10
16
Gravesend, Kent, UK
Rapido Le Randonneur
Hi everyone,
I have taken the plunge and subscribed as I have an open and shut problem and hope to be pointed to a helpful thread.
The Habitation door on "Jennifer" an 08 Rapido LeRandonneur 965M has dropped on the hinges.
The door shuts but does not lock properly. I am an engineer so usually quickly repair or adjust stuff
I have adjusted the twin lock pins but no improvement.
The hinges are strange double pin internal affairs Door hinge photo(Small).jpg
The pins and tracks are worn.
Brownlows and Rapido are saying I need a new door and frame (Which they can't fit) at £ 7500.00
I have tried multiple people and companies for spare hinges or aftermarket door.
Has anyone else had this issue and how was it resolved.
We love "Jennifer" but can't justify £7500
Pommie 82
Oct 12, 2009
10,718
23,756
A Class N+B Arto 69GL
Since 2009
Hi everyone,
The hinges are strange double pin internal affairsView attachment 852668
Pommie 82
We had a locking problem on our N&B Arto while on tour, since resolved, but we solved it by getting an external lock fitted - lot cheaper than £7,500.
Our problem was that the door was not shutting completely to allow the locking mechanism to engage when turning the key outside, but the locking knob worked from inside. Just needs a good shove from outside.
Nov 13, 2011
1,483
3,531
Lincolnshire
PVC
30 years
Remove the hinges, one at a time. Withdraw the pins. Obtain some oversize rod, cut to length. Drill out the other bits (no idea what they would be called)
Geoff
Two on Tour
10,383
51,378
Elddis Autoquest 175
Since 2010
Hi everyone,
Pommie 82
Looks to me that if the door is raised and held i.e. a block of wood and a jack, and the pivot pin (arrowed) removed, then the washers between the hinge elements can be removed and replaced with thicker washers to take up the wear.
Pommie82
Apr 24, 2023
10
16
Gravesend, Kent, UK
The wear seems to be in the aluminium channel that the pins slide in, The inner end of the pins and metal spacers have sunk into aluminium. The pins are tight in the right angled hinge elements. I think I will have to commit and remove 1 hinge and see if I can lift it with spacers and tighten the worn slot
Pommie82
Apr 24, 2023
10
16
Gravesend, Kent, UK
I was hoping to avoid an external lock
Pommie82
Apr 24, 2023
10
16
Gravesend, Kent, UK
Geoff
I think I may need a combination of thicker rod and spacers to correct the wear.
This is why I was looking for new hinges
C'est la vie!
Lenny HB
53,663
150,850
On the coast in West Sussex
Hymer B678 DL
The hinge will be a standard hinge bought in by Rapido just a case of internet searching. Those hinges are known by 3 names, Hidden Hinge, Invisible Hinge & Concealed Hinge.
As it's a French van could be worth searching with French search engines like Google.fr.
Worth contacting manufacturers of similar hinges email them with a photo they may be able to point you in the right direction.
Pommie82
Apr 24, 2023
10
16
Gravesend, Kent, UK
Pommie82
Apr 24, 2023
10
16
Gravesend, Kent, UK
Good shout with google france
Jul 7, 2021
1,515
5,338
dont own one yet.
Just take a hinge out and bring to a fabrication shop, and they will replicate / improve some nice new hinges for you, not a difficult job when you got the right equipment, if you want it on the cheap, go into a college where they have the proper gear too and like a challenge for their students🤷🏻‍♂️😎
Pommie82
Apr 24, 2023
10
16
Gravesend, Kent, UK
Finally collected Jennifer and removed a hinge.
It turns out all the bushes are worn on the top hat and internally.
I discussed with my Son in Law who has a High End 3D printer
He drew up the 3 sizes of bush and printed a couple of samples in Kevlar impregnated polymer.
Once we had the sizes right, he printed 3 sets of bushes.
I stripped cleaned and reassembled 1 hinge at a time.
The door now sits central in the frame and the locking bolts locate perfectly.
£ 20 fix instead of a £ 7,500 new door and frame as advised by Rapido
Apr 13, 2019
1,950
48,427
Nottinghamshire
Ci Coachbuilt
Since September 2018
Nice one.
Result!!!!!!!
Love it when a bit of thought is put to exercise rather than just accepting a " fobbed off" answer.
Love tinkering with bits on our old motorhome like this.
Oct 12, 2009
10,718
23,756
Since 2009
View attachment 864543View attachment 864541View attachment 864542
Well done that man!
Jan 22, 2017
510
1,971
Bristol
DAF LF Conversion
Since 2013
List them on ebay and put a link in this thread. You might sell a few!
Derbyshire wanderer
1,299
2,406
Derbyshire
C class
15 years
You cannot beat fixing things that are supposed to be unfixable. Well done.
Now wait for the requests for others needing new bushes 🤣👍
Jul 29, 2007
6,554
39,738
Ipswich
RV and PVC
30 years
Look up SOSS or concealed cross hidden hinges, you might find a replacement.
