tick59
When my motorhome is plugged into mains everything is ok ecept when you switch the water heater on then the house electrics blow. Have checked fuses in van all ok only the house electrics affected. ????
Have a look at this picture. It shows an electrical box with one RCD on the left, and three MCBs on the right. The RCD is quite wide, and has a small button in the top left, labelled 'Test'. Note that older wiring may not have an RCD at all, and sometimes two RCDs are fitted.When my motorhome is plugged into mains everything is ok ecept when you switch the water heater on then the house electrics blow. Have checked fuses in van all ok only the house electrics affected. ????
It actually does NOT tell you that there is a break in the element, it does tell you that there is a possible circuit to earth, no offence but I’m glad that I never asked you round to check my immersion or earth faultsyou may not be able to do the full test but getting a circuit from one terminal to the shell of the tank does tell you there a a break in the element ive been testing immmersions that way for years
Sorry was totally correct an MCB is not a RCD is not an RCBOYou are partially correct, but you can get an RCBO trips out on overload and earth fault current, basically directly swappable with mcb’s
When correct, PEDANTIC I am , have a good daySorry was totally correct an MCB is not a RCD is not an RCBO
they are all different devices. The later incorporates both of the former but is not the same.
Pedantic he is:
We do get down that way occasionally (pandemic allowing) and I never turn down the invite of a beer meet, we do quite a bit of overnighting at a pub in Hook, be good for a temp meetsounds like a subject we could debate over a pint or 3 post apocalypse.
Brill that Tales from the uninflected!Happy to share a pint and tales of the un-infected.
But could I ask which Hook village? county would be good as we have lived near several.
Don’t know why you feel the need to use capitals. I never said to test for earth leakage just continuity. Just trying to help the OP. Only thing worse than bad information is wrong information.That would only tell you if the element had continuity or not IT WOULD NOT TELL YOU IF THERE WAS AN EARTH FAULT
No offence but that would appear to be what your doing, continuity is NOT the problem, (the problem is OBVIOUSLY earth leakage, which you will not find with a multimeter) CAPITALS, well thats an emphasise to a get to a point, you have a good dayDon’t know why you feel the need to use capitals. I never said to test for earth leakage just continuity. Just trying to help the OP. Only thing worse than bad information is wrong information.
Pretty much confirms the heater element is faulty.All lights sockets and plugs go off, Once i switch the water heater off and reset the Electrics in the house everything works except the water heater.
It does show a break in the sheathcontinuity shows a break in the element and resistance will also show a fault but as a first test it usually worksIt actually does NOT tell you that there is a break in the element, it does tell you that there is a possible circuit to earth, no offence but I’m glad that I never asked you round to check my immersion or earth faults
Yes, fault in heater element, or possibly the wiring to it. Almost certainly needs replacing.Pretty much confirms the heater element is faulty.
Moving on from the heater element fault, what exactly did you reset when you reset the electrics? From the picture in post#32, can you tell if it was an RCD or an MCB? I'm asking because there could be a problem with the MH electrics.All lights sockets and plugs go off, Once i switch the water heater off and reset the Electrics in the house everything works except the water heater.
Love to hear your guys thoughts on earth reference wire or not on RCBOsWhen correct, PEDANTIC I am , have a good day
Looks like your heater element is faulty, and the protection circuits are doing their job.Test button trips
240v is available to USA houses for bigger electrical devices2 x split phase 120v go to their properties.
Hi, Sorry for earlier post, just sometimes folks pose a Q and are never heard from again.All lights sockets and plugs go off, Once i switch the water heater off and reset the Electrics in the house everything works except the water heater.
Put a post up for auto electricians in your area, good luckMy van is fourteen years old and has just developed this fault would an auto electrician be able to fix it ?
They would probably be able to find the fault in a couple of minutes but are unlikely to be interested in pulling your van apart to get at the boiler to strip it down and replace the heating elements if that's what the problem is. Caravan/Moho specialist to sort that if it's the problem I'm afraidMy van is fourteen years old and has just developed this fault would an auto electrician be able to fix it ?
The RCD is designed to trip in the event of a live or neutral to earth fault . Generally the trips are set to operate when a leakage of 30 mA is detected. This means that the appliance conductive surfaces will not reach a voltage higher than 50 volts before the rcd operates isolating the circuit and hence providing shock protection. The MCB also provides protection from fire and shock if their is a fault to earth or a short circuit in the appliance but will not protect against shock if there is a disconnected or bad earth and a live or neutral to earth fault on the appliance at the same time. If the rcd is tripping then there is a leakage to earth somewhere and it could be on either the live or the neutral supply cables or more likely on the element of the water heater. An insulation resistance test is required on the supply cables and on the appliance to determine where the fault is. If you are not a competent person ( electrician ) then you need to consult one who will have the knowledge and the equipment to diagnose the fault quicklyWhen my motorhome is plugged into mains everything is ok ecept when you switch the water heater on then the house electrics blow. Have checked fuses in van all ok only the house electrics affected. ????
So how does that work?By and large the kitchen ring main has the highest load capacity, try plugging the ehu into one of the kitchen sockets, if it still trips then likely to be a fault on the motorhome
