On mine, If ehu plugged in it will give 240 irrespective of that button position. The button turns the onboard charger on / off.I've ordered one from Apuljacks. Was odd that it seized so completely, absolutely stuck fast and, despite being stuck in the off position it still lit up and the 240v system worked...
d
Yeah, I sort of figured out or guessed that the button was simply turning the charging system on and off. As I have a solar charger it was hard to tell as the leisure battery was always full. I'm hoping the replacement of this switch will sort it. Incidentally, the replacement switch is green as per the manufacturers documentation but the fitted switch that's failed is orange. Mind you, nothing ever seems standard in MH world, it seems like they fit whatever's on the bench at the timeOn mine, If ehu plugged in it will give 240 irrespective of that button position. The button turns the onboard charger on / off.
