Are you saying that the Google maps have never taken you down unsuitable routes, for your size and weight of MH?
Cheers,
Jock.![]()
It must do Jock as it thinks you are in a car, surely?
Cheers,
Jock.![]()
Not yetAre you saying that the Google maps have never taken you down unsuitable routes, for your size and weight of MH?
Cheers,
Jock.![]()
My sentiments entirely Paul.It must do Jock as it thinks you are in a car, surely?
Paid over £100 for truck map data. I expect it to be reasonable. As someone has said, the problem more likely is in the software than in the mapsKeeping map data up to date takes time and money.
If you don't subscribe towards the cost of maintenance, it's a bit rich to expect the data to be accurate.
Ive done this with roads I'm concerned about, and even done the streetview to home in on the tricky looking places.
Not from me Jon, as I've never used Sygic so can't comment on it.I get your recommendation for Sygic
Ditto Jon, but since using a SatNav with iGo software and Truck specific mapping (containing .ftr files) in the MH, I've not been caught out.@JockandRita , just to answer your earlier question Jock, Yes I ve been caught out before and during the various satnavs but always managed to extract myself.
Round our way a new road was opened a couple of months ago and part of the old road closed. This was updated overnight in Google Maps and which now frequently has European trucks sitting on the roundabout puzzling over where they went wrong, so many are not using Google Maps.My sentiments entirely Paul.
You only have too look at the number of Easter European Truck drivers relying on Google maps, who have come unstuck here in Britain, never mind anywhere else across Europe.
You must be joking.One is more than enough.Where can I find a second wife???
I cannot comment on the grounds I may incriminate myself. Plus I'm not that brave!You must be joking.One is more than enough.
Still no better! I tried it out, input all the relevant weight/size data and then plotted a route from mine to York (33 miles). It initially took me out of my village via a route that is totally unsuitable to anything much bigger than a Land Rover! Including a 3.5t weight limit bridge and a VERY narrow lane!! Bloody useless.Paid a lot of money for Sygic Truck 3 year licence about 18 months ago and have been complaining about it off and on ever since. Firstly because despite it saying I takes into account weight and size for RV/Motorhomne routing, they admitted that it doesn't if you are over 3.5t. They said they would be correcting this.
Also had some terrible routing decisions and lack of rerouting.
I have been receiving their updated releases for testing and have been hoping these would be corrected. Decided to take the van out for trip today just because it had been standing a while. Set the SatNav for a destination in a village about 13 miles away on Motorhome setting - navigation said it would take an hour (!) to get there. (Google maps said 28 minutes)
So, off we went - Sygic decided I should take a narrow lane route - so narrow in fact that I ended up at a 6' 6" wide bridge which I clearly couldn't cross - fortunately I was aware but just wanted to see what it did. OK, turn around, set it to Truck and try again - same result 6'6" wide bridge on the route. Did take me an hour in the end due to the route it chose.
Came back and Sygic just couldn't sort it out - eventually just reverted to Google maps for sensible route via main roads.
Don't buy this app!
I've got one you can have.Where can I find a second wife???
Be careful what you wish for…………Where can I find a second wife???
I have been switching between Sygic Truck and copilot truck of late running on my iPad - Sygic seems to have improved. I also have either google or apple maps running on CarPlay, however a typical exchange when navigating out of town whatever I am using runs like this...Still no better! I tried it out, input all the relevant weight/size data and then plotted a route from mine to York (33 miles). It initially took me out of my village via a route that is totally unsuitable to anything much bigger than a Land Rover! Including a 3.5t weight limit bridge and a VERY narrow lane!! Bloody useless.
Demand your brass backPaid a lot of money for Sygic Truck 3 year licence about 18 months ago and have been complaining about it off and on ever since. Firstly because despite it saying I takes into account weight and size for RV/Motorhomne routing, they admitted that it doesn't if you are over 3.5t. They said they would be correcting this.
Don't buy this app!
It would appear that neither of the systems both of you are using, have the "all important .ftr Truck Files.I have been switching between Sygic Truck and copilot truck of late running on my iPad - Sygic seems to have improved. I also have either google or apple maps running on CarPlay, however a typical exchange when navigating out of town whatever I am using runs like this...
SatNav: turn left
Me, take a quick look: I don't think so - drive on
SatNav : turn left
etc
Even when the turn left is a perfectly fine road you can see cars parked on both sides presenting a narrow challenge!
My rule of thumb is that if a bus or bin lorry goes that way then that will be an OK route - and I still get in a mess!![]()
Well done VascoMy satnav decided not to work half way across Spain .... had to use the map and road signs - I got here !!
Did try initially - wall, head, banging - arrange as appropriateDemand your brass back
Will see what I can seeIt would appear that neither of the systems both of you are using, have the "all important .ftr Truck Files.
Many Sat Navs or Apps claiming to be Truck Sat Navs systems, arrive with all the mapping with files, ie, .fbl, .fpa, .fsp, .fda, and .fjw...................but not the all important .ftr, which is the necessary Truck File recognising the dimensions and weights entered, and steers you clear of unsuitable routes or hazards for your type of vehicle, according to it's size, weight, length, number of axles, and (declared) hazardous goods.
I know, as I have updated many brand new units claiming to be Truck Sat Navs, which have been nothing other than Car Sat Navs, but once the correct files are installed, the units become a complete different in their own right as Truck Sat Navs.
Even if not a Truck, but used in "Car" mode, you still need the .ftr file for the unit or App to recognise dimensions and weights, etc, of your vehicle.
I used to subscribe to Co-Pilot, where you could enter the dimensions, etc, and it would actually guide you correctly for that size and weight of vehicle, but things changed, (a takeover or change of software possibly), and the system became absolutely useless for anything other than a car.
iGo software, and up to date HERE mapping with the correct .ftr files are absolutely spot on, and is the way to go.
PaulKW and ceejayt, can either of you connect your units or SD cards, directly to a PC, and access the files installed to check for .ftr Truck Files? With the Apps, I wouldn't know how to access the files on those, to check.
Cheers,
Jock.![]()
try the ‘Not fit for purpose’ report them to trading standards, it sounds like others have had similar issues so the evidence is there that it’s crap for MH’sDid try initially - wall, head, banging - arrange as appropriate
Theres no way i'm having 2 Mrs Bob'sThat's why you should have 2 of everything.![]()
