- May 12, 2019
- 545
- 796
- Autotrail Delaware
- Years Tugging - Newbie MHing
CPheonix
I’m guessing you have a Frontier Delaware? The Sargent unit (EC700 and PW300) does not have a B2B, it is in fact limited to 20amp charging where a B2B is likely 60-80 amp. If your batteries are not depleted before travel the engine will likely get them back to full in 2-3 hours with the EC700. With a B2B you should be able to get a reasonable charge back in the battery after fairly deep depletion in just an hour or so.
Seems if you increase the battery bank beyond 200 amps you will need to change the charger too, which works when you are on an EHU. That’s what I have been advised.
I’m looking at similar situation and currently, unless I get some definite reasons not to do so, I intend to change my 90ah batteries for two 140ah agm, fitting a B2B, an extra 150w of solar, and retain everything else the same (Sargent etc). Solar to feed during the day when we use little power, and engine charging at least once per day if the batteries actually need it or we are travelling. I’ll accept slower charging when on EHU.
Only other additions will be a stand alone inverter (3000w Max) to feed microwave, toaster and hair dryer on an as required basis, with a remote on/off, connected directly to the battery. Plus a BM 700 battery monitor so I can directly monitor what the battery situation is at all times.
I’ll follow your thread with interest to see what you eventually do! Best of luck with it.
