- Jan 28, 2008
- 10,329
- 18,906
- Renalt burstner
- 7 years campers before that
at 3500 youl probably be ok im sure i saw you state 3000kg mam earlier in the threadThanks for your advice. But I very much doubt I'll be over, or anywhere near over. As I have already said I will be getting it weighed to be sure. But no point until I have finished.
I have looked into it actually.
The kerb weight of an L3H2 is 2025 kg (as I understand it kerb weight includes driver at 75 kg plus full fluids - diesel, coolant etc). Limit is 3500 kg. So load allowed to be added is 1475 kg. That's almost one and a half metric ton!
I don't think I'll be over that. I don't have much that weighs a lot, not really.
I have no big fresh water tanks (only one plastic 25 L jerry can). No grey waste tank (only one 10 L jerry can). Black waste is a little porta potti. No gas yet but that will be one single refill bottle. So no big heavy tanks that most conversions and professional built MHs have.
Inside I think I'm fairly standard, if a little smaller even. One double bed (built with bed slats, not a solid sheet of ply), one bench seat (made with framing batons and 7 mm cladding which is very light weight - 10 pieces at 2.4 M is only 3.5 kg), one pair of B&Q kitchen cupboards, two home built above kitchen cupboards (made with box framing, thin cladding and a base of 6mm ply). Most vans have a kitchen on both sides. I only have it on one.
I'm not worried in the slightest but the weighbridge will tell me, eventually.
